| Home > Help Needed / General Tech Chat > Starting issue | |||||||
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
29th Dec, 2015 at 01:08:21pm
29th Dec, 2015 at 02:03:39pm
I would imagine either EDIS unit or Coil pack.
29th Dec, 2015 at 03:01:25pm
Hi Jonny,
17 Posts Member #: 9903 Member Northern California |
29th Dec, 2015 at 03:29:09pm
Which two plugs are wet,and which are dry? |
29th Dec, 2015 at 04:58:27pm
brp 7es plugs
29th Dec, 2015 at 04:59:05pm
i'll get back to you Frog in ahalf an hour and check. |
29th Dec, 2015 at 05:12:57pm
bpr 7es even lol |
29th Dec, 2015 at 08:30:06pm
Crank sensor polarity correct?
29th Dec, 2015 at 08:38:55pm
Also make sure ht leads are fitted in the correct order On 26th Oct, 2004 TurboDave16v said:
29th Dec, 2015 at 09:14:22pm
Shielding on the crank sensor wires earthed correctly? On 11th Feb, 2015 robert said:
29th Dec, 2015 at 09:27:26pm
something i would like to add that if its a new build the plugs get a oil petrol wash and sort of a glaze on them unleaded hi octain fuel dont help they play up had it Many times so............ fit new plugs after you have checked all the other problems the the chaps have sugested
31st Dec, 2015 at 09:46:11am
Okay checked all of the above. The only thing I'm slightly concerned about is the air gap. What should it be? I've measured mine and its 1.3mm. |
31st Dec, 2015 at 11:48:28am
Normally specified at 0.5 -1.0mm so may be your problem. |
31st Dec, 2015 at 11:28:52pm
Altered the crank sensor bracket so the gap is now 1mm and it runs like a dream!
