| Home > Help Needed / General Tech Chat > Exhaust Clamp | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
30th Dec, 2015 at 04:58:27pm
On my standard 1275 exhaust keeps leaking on the clamp exhaust downpipe to manifold it's standard cast manifold with 1 outlet. The downpipe not sure if its off a 998 or are they all the same diameter around the neck? The clamp I have seems a bit slack, but the other type for the 998 won't fit, is it a case of just putting exhaust paste round it or is there any ways of getting clamp tighter or something cheers |
30th Dec, 2015 at 07:55:00pm
If it's got putty on it already, this could be the problem. Take it off clean all the putty off both parts and then reassemble with some good quality stuff.
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
31st Dec, 2015 at 09:44:03am
You could always apply a bit of pressure in the form of a trolley jack to seat it while you are doing the clamp up. |
