| Home > Help Needed / General Tech Chat > Intake Air Temperature | |||||||
2nd Jan, 2016 at 03:18:18am
what temps do you guys see while under boost? how hot is to hot? |
2nd Jan, 2016 at 11:54:54am
There was a thread that mentioned 39deg but I'm not sure it was ever proved.
2nd Jan, 2016 at 12:11:09pm
well, as an example,
2nd Jan, 2016 at 12:25:54pm
We had some realty cheep screens with temp sensors un the metro can. One either side of big front mount intercooler. We would get about 30degrees drop on about 15-20psi, running at 35-40•c at the plenum On 11th Feb, 2015 robert said:
2nd Jan, 2016 at 02:01:16pm
On 2nd Jan, 2016 apbellamy said:
We had some realty cheep screens with temp sensors un the metro can. One either side of big front mount intercooler. We would get about 30degrees drop on about 15-20psi, running at 35-40•c at the plenum Those numbers dont add up Andy. The heat of compression alone at 15psi and an unlikely turbo efficiency of 75% would see discharge temperatures in and around 110c with an ambient of 20c so there had to be a bigger temperature difference across the intercooler than 30 degrees to achieve 40c at the plenum?....... On 26th Oct, 2004 TurboDave16v said:
2nd Jan, 2016 at 02:08:07pm
Probably a bigger drop. I've just watched a video of it on 17psi on rollers and it was hitting just short of 40 degrees. If something is worth doing, it's worth doing half of. |
2nd Jan, 2016 at 02:34:00pm
It's been a ling time since we had that car Col, it's more likely to be my memory letting me down. It has stuck in my mind as we were surprised by the difference the big I.c. Made. Just the actual numbers that are fuzzy. On 11th Feb, 2015 robert said:
3rd Jan, 2016 at 07:16:56am
My iats would stay around ambient unless i was propper hauling ass
Yes i moved to the darkside |
3rd Jan, 2016 at 07:19:47am
ok so basically you'll be considerably down on power before the temp gets to the point of doing damage as long as the AFR is good |
