Home > Help Needed / General Tech Chat > Banded steels offset and brakes
ian2000t
Member #: 2764
Halesowen
I've decided the 13's and sports packs are going, and I'm going with Wood &Pickett arches and banded 10" wheels.
I was thinking standard 10*3.5 wheels with 2" banded onto the outside (10*5.5). Does this sound about right to fit under standard wood & Pickett arches? Has spacered drums on rear and MG Metro brakes up front...currently.
What brakes are best to run under 10" steels? I've read that Fiesta brakes won't fit - is that right?
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
Shaunas 3.5x10 steels on a cooper S brake setup sticks out archless about 10mm at the front and flush at the rear if that helps mate
D4VE
Member #: 10749
lowestoft suffolk
Sound roughly right for arches yet the fronts might need the metal arch trimmed for clearance and the wp arches need that lip to be mounted.. (might not be there if you already have sp wheels n arches) and for how cheap the 10" brake conversion is nowdays ya might aswell stick with them.. essex banded wheels are the best place i know.. (they done the splitscreen campers wheels on wheeler dealers) not sure ya insurance company will like them im afraid...
Edited by D4VE on 3rd Jan, 2016.
Nothing gets past Dave lol
jonny f
Member #: 9894
Dorking
Barely any brakes fit under the standard steels.
7 inch cooper or 7.5 inch cooper s
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Bear this in mind, 10" steels will take an S brake set up but that's about it.
On 7th Nov, 2008 Nic said:
naeJ
m
kezzboycat
Member #: 10371
leicestershire
Treat the bandits like mambas
nothing above 7.5 in my book I've seen people use large spacers to take the wheel away from bigger callipers but personal would feel safe
https://www.youtube.com/watch?v=li_7fyhK7pE
PhilR
Member #: 10034
Birmingham
I measured up the 3.5" dunlops for banding but couldn't see how to get the clearance I wanted.
Have you considered 12" steels. The standard 12" are clearly ugly, but banded ones look suprisingly good IMO (and your 8.4 brakes will fit).
Edited by PhilR on 3rd Jan, 2016.
Shauna
Member #: 10424
Swansea boyo!
I'll be taking off my tatty winter 3.5x10s in the next few weeks if you want one to play with?
ian2000t
Member #: 2764
Halesowen
Thanks for the offer Shauna, might take you up on that!
Don't really want to go 12's, I actually only like 13" or 10" wheels on Mini's, depending on the style of mini. Wings are new panels, so we'll be cutting for clearance then adding the lip back on for mounting W&P's.
So, Fiesta brakes fit with a 3mm spacer?
Cooper S 7.5 is a definite possibility.
Will the Minisport 7.5" alloy kit work? Are they worth the extra cost over Cooper S?
http://www.minisport.com/mslms03-7-5-brake...abs_description
jonny f
Member #: 9894
Dorking
See my post above, only brakes that fit under them.
No off the shelf alloy ones fit.
I would fit Cooper S and mintex m1144.
ian2000t
Member #: 2764
Halesowen
OK thanks. Minisport site suggests their kit works for all 10" wheels. (Not the 7.9 alloy kit).
Video posted above suggests Fiesta kit works with 3mm spacer.
jonny f
Member #: 9894
Dorking
I searched high and low in 2010 for some to fit under them.
Without spacers they were the only options.
Might be worth asking maybe the designs changed. Specialist components do some calipers now to that look low profile.
Here they are, I loved the wheels :).
Shauna
Member #: 10424
Swansea boyo!
I changed my mintex pads last week and they still had plenty of meat left in them after two and a half years and over 10k.
When I've swapped them over I'll leave one with Carl for you, I've got 10 3.5s haha, love them although I'm probably the only one who does! I do like banded steelies on the right car, not sure how they will look on yours if you plan on having them white too. Why are you banding 3.5s and not 4.5s?
Edited by Shauna on 3rd Jan, 2016.
D4VE
Member #: 10749
lowestoft suffolk
Ahhhhh that was your jonny... i remember seein it about.. what are they banded too? and did they protrude the std arches?
I believe robert said there is 3mm clearance.. not 3mm spacer?
jonny f
Member #: 9894
Dorking
Yea that was my first car :). Exactly the same as Ian is thinking of. 5.5 inch.
They had a great fit. Just a little poke out of the mini special arches but no tread showing. So should be the same and look great with w&p arches.
ian2000t
Member #: 2764
Halesowen
That looks great mate. Will check with Minisport and SC.
Shauna, I'm going Old English White car and arches, but with Anthracite banded steels and chrome hub caps. Using the 3.5's as they are the cheaper and easier to find. Also, doesn't make any difference when you're banding if you add a 1" band, or a 2" band.
D4VE
Member #: 10749
lowestoft suffolk
Do ya have anyone in mind for banding?
