Home > Help Needed / General Tech Chat > Many thread but not a answer on Rts
kezzboycat
Member #: 10371
leicestershire
Well I have built a Rts clutch and quite concerned on the clutch cover. the cover was a few mm of the inner housing enough to tightened the bolt to start them and then tight them with a socket to pull it in but I feel it's a lot of force would it maybe be because of the springs ? The cover slid on when I took the trust cup out
The pedal is hard but I'm sure that will feel better after a while nothing is fowling bolt wise turns over freely by hand
PhilR
Member #: 10034
Birmingham
The aluminium clutch cover shouldn't sit proud. If you have to tighten it against the spring, the clutch will never fully disenguage engage.
Did you use Valeo or AP parts? Have you got another flywheel and clutch to measure and test against?
Edited by PhilR on 3rd Jan, 2016.
kezzboycat
Member #: 10371
leicestershire
On 3rd Jan, 2016 PhilR said:
The aluminium clutch cover shouldn't sit proud. If you have to tighten it against the spring, the clutch will never fully disenguage.
Both are ap parts I have another flywheel and clutch somewhere seems abit strange to be honest also checked the bolt see if they were pushing the back but they are not
jonny f
Member #: 9894
Dorking
You've got something wrong there.
Did you try the cover on before fitting the clutch?
kezzboycat
Member #: 10371
leicestershire
Yes it's fits fine
problem when the sleeve is on it pushing it outs so something is on the large side
Just don't know what yet can't really see the flywheel being massively different size only thing that Spring to mind the middle but of the diaphragm being to big
jonny f
Member #: 9894
Dorking
Can we get some half decent grammar with that? Lol.
Do you have a picture of your assembled clutch?
What angle are the springs at with it all assembled?
What throw out bearing and plunger are you using?
kezzboycat
Member #: 10371
leicestershire
sorry lack of sleep last night well 2 hours or so
Haven't got any picture to hand can get some
What angle should I be looking for regarding the springs ? What rectification can I do if they are on the high side ?
kezzboycat
Member #: 10371
leicestershire
plunger is
https://www.minispares.com/product/Classic/....aspx|Back%20to
clutch bearing one of these
http://www.ebay.co.uk/itm/CLASSIC-MINI-GRB...kqju5UwNUmVHueA
hope this helps
Put some pictures up.
The 'plunger' you link to is in fact tge thrust sleave.
Its dificult to get any perspective on the problem you are experiencing.
Without pictures of all the parts you are using and how they have been put together any further suggestions will be fruitless. It could be anything. If yiu cant see the problem with the parts infront of you, then, without pictures, neither can we...... post up some good pictures *wink*
PhilR
Member #: 10034
Birmingham
Get a photo of tips of springs' fingers. I tried a few springs together and although they were all valeo, some pairs didn't fit that closely together
kezzboycat
Member #: 10371
leicestershire
Shall get some pictures by the weekend for you guys to look at
jonny f
Member #: 9894
Dorking
What was the problem then?
