Home > Help Needed / General Tech Chat > Valve size
jonnyturbo
Member #: 676
basicly what is better bigger inlet or exhaust valves on a turbo engine. Should i leave them standerd,should i do both. Will bigger exhaust valves reduce lag through better flow?
there are a lot of ifs... and buts on this one, turbo size, air speed velocity etc etc... it all depends what you want from the motor it can be very indepth
but in general 35.5mm inlet & 29 to 30mm exausts is what most guys on hear go for
seems optimal !
other users on here i would like their comments.
one thing to watch is the port size dont go too large on these as this demotes port velocity
which inturn affects lag and low speed driving
head work is a large subject like i said depending what you want the engine for
ben:
Doodmeister
Member #: 149
Alberta, Canada
This Slark Head is very good. I used one years ago and i'm looking to get another very shortly.
STOR - ?950 + vat
For serious turbo/supercharged applications. Exhaust valve is offset giving straighter ports. Using 32mm exhaust and 36mm inlet valves. The chambers can be reliably increased to 30cc for lower compression.
Or Vmax do a head with 36/32 valves for about ?550.
Phil. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
or morspeed!
*wink*
Alex
AlexF
jonnyturbo
Member #: 676
The head i am useing was done by slarke it has 36/29 with 31cc chambers and minimal flowing it seems to work well.I now you can use cut down montego turbo exh valves has anyone had this done will it be a worth wile mod?
most of us just use stainless exhaust valves. We don't bother with the sodium valves.
