| Home > General Chat > Teeny little problem... | |||||||
110 Posts Member #: 125 Advanced Member |
26th Jan, 2004 at 09:47:56am
I chopped up a Metro Turbo on Saturday and took all the relevant bits home |
![]() 323 Posts Member #: 41 Senior Member |
26th Jan, 2004 at 12:30:33pm
unlucky mate, i've always worried about the rope i use to lift the engine in and out snapping and the engine landing on the turbo, maybe i should stop worrying about it or it might happen lol
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
26th Jan, 2004 at 09:01:51pm
Turbo carb is a sealed item, so a standard carb off a normally aspirated engine won't be any use. The Turbo dizzy has an advance curve tailored to the engine, so again it will be best to use the correct item. Try putting an add in the wanted section on this site as these items seem to go for stupid prices on ebay etc
111 Posts Member #: 29 Advanced Member Croydon |
27th Jan, 2004 at 01:17:12am
Too many projects! |
We kept the engine on the front subframe with wheels still on to make it easier to move, however as we lifted it out of the van the engine crane toppled and the engine landed on it's carb
The carb smashed into a squillion pieces and the dizzy shattered too, but no other damage (thankfully!).
