Home > Beginners Tech > Sc gears and helical drop gears
fixitphil2
Member #: 10945
scarborough/ northyorkshire
hi ,can someone explain why it's ok to run a sc gear box with helical drops or vice verser, I'm building engine and box to take 150 bhp reliabley with mini spares clubman sc gears but using standard drop gears, cheers
Correctly shimmed drop gears of the later A+ type (larger idler bearing) are perfectly capable of way over 150bhp, ask Robert.
A helical box is on it's limit at 150.
I would also ensure the bush in the primary gear is not worn too.
fixitphil2
Member #: 10945
there is a bit of play on the primary gear bush but not got a new one to compare,i had 9 thou on idler when i stripped it will be setting to 4 thou,il have to find internal diameter of a new one
fixitphil2
Member #: 10945
hows fitting sc drops helping a helical gear box tho,is it the combination of the side loads from both at the same time the problem,as alot of people have just sc drops
it isnt.
When you compare the section thickness of helical drops there is probably at least 50% more contact patch/section thickness compared to the gears in the box, hence why those are the ones that need uprating.
Edited by minimole23 on 16th Jan, 2016.
A primary gear too tight is worse than it being too slack in my experience (within limits of course).
If you run s.c. drops with a helical gear set, the rest of the box needs to be in tip top condition.
We did this in the metro van on a used box with about 150 bananas and found the first motion roller bearing collapsed when we pulled it apart. More than likely caused by emergency starts on the strip..
Cables123
Member #: 11097
i did the same as apbellamy with less than 150bhp using standard drops and gearset with a 1380, TWICE! I rebuilt the 3rd time with straight cuts throughout, i really dont want to splitting the engine again to fix the box
Take it from me, helical drops and minispares clubman set will take what the engine produces, fit new bearings all around and your sorted.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
imo its all about how much it gets abused i broke the bearing cage on the dubble roller a timken bearing by the way on a stock 1100 + mild cam if your rough on it then nothing will last but as ive lerant if your kind to it youll get away with more
Certainly on the metros...cant recall the number of balls in them. But one type used, every single gearbox I took apart that had it, the cage was always broken. Didnt matter what age or mileage or engine size, they were all broke.
If you replaced it with the alternative which had either 1 ball more or less ( cant recall which ), they never really broke
