Home > Technical Chat > turbo for a 1.8k-series
Good evening guys, I have been trying to get my head around flow maps etc but not having much luck, I am building a 1.8t/vvc hybrid (1.8 turbo bottom end and vvc head). Now I am looking for a turbo which is good for up to 250bhp but at a realitivly low psi not going above 15psi
Does anyone have any suggestions preferably t25 pattern.
I was also wondering if it were possible to do a gt2052 hot side with a gt2560 cold side?
hmmmm,
I reckon a bar of boost with a good head should get the job done??
that means a GT28, or TD04 16G.
careful you dont split the liners....
anything is possible, i spoke with one about creating a bb gt2056 with larger compressor,
although i wouldnt bother with a hybrid when there are countless brands and models of turbos in the 250bhp capable catagory
I know about the liners but pistons will fail before them, I just want to see what it can do on a very small budget. The thing with the gt28 I was thinking it may take a while to spool as it's only a 1.8
they run twin gt28s on RBs, effectively 1.3l per turbo, they are considered the most responsive way to make 600bhp
they are a few a/r options and trims on the gt28s,
they are considered to be quite a small turbo on the honda 1.8s obviously they have the revs to use the turbos though, coming on boost around 5k is no problem they have another 4500rpm left to go hahaha
what will the peak revs be
Fair enough I did not know this, do you know the exact number for if?
Max rpm will be 7k so I don't have to get stand alone ecu to map the vvc
Edited by Paul R on 4th Feb, 2016.
evolotion
Member #: 83
Glasgow, Scotland
200sx (sr20det) t28 spooled on my 1.4 at 4500 or so k rpm. The toller bearing variant should spool sooner (s15 silvia). The pulsar t28 spooled at 5k. All were perfectly useable, given your increased capacity and head flow youd probably spool one just fine, pulsar turbos are fairly cheap and easy come by.
Denis O'Brien.
They run the GT28 on R5s and they seem to spool fine too.
Cheers guys, will keep an eye out for them.
also theres probably a few gt25's from focus RS's about, that could be ok.
GT2560R, it will spool up quickly lower in the rev range, you will need more than 15psi, but more driveable in the real world than something that doesn't spin up till 5k rpm.
