Home > Help Needed / General Tech Chat > No engine number
Mjjenkins01
Member #: 11306
Rhondda
I bought a metro turbo engine a few months ago but it has no engine number plate. Is there anywhere else i can get ut from?
Nope, why you need it?
probably for infor for the dvla for an engine change?
if so the plate is often lost when the blocks skimmed, a lot of rebuilders stamp theyr name and a number eg MED 1293 456.
you can just make somthing up and stamp it on and if they ask say its a rebuilt engine.
aparently
New engine number:- BIG-8008S
Pmsl!!!
I had to give the insurer an engine number for mine.
Mjjenkins01
Member #: 11306
Rhondda
I need it for dvla i got the old engine number for my std 1275 will that do?
I just took the small aluminium plate off the engine that had originally been in the car so the number remained the same (both were 1275 engines as I had changed from 998 to 1275 decades ago back when DVLA were less fussy).
I can see the issue on modern engines where everything is stamped or engraved but on the A series it's just an easily removed plate.
I can't see it being an issue in this case unless the same number shows up against two different registrations.
I don't imagine the DVLA would check this. I had the same engine number on my Jet Black and Clubby Estate for a long time before I realised.
Rammie2000
Member #: 10190
belgium
Put an number of an old 850 on it
D4VE
Member #: 10749
lowestoft suffolk
Just leave whatevers on the logbook on there..
Nothing gets past Dave lol
Mine is a late bloke with the number engraved so the skim removed all traces. Stamp it up with whatever you want, but i dont like the idea of using a number from an engine you don't own, leaving yourself open to VOSA's pedantry, not that its likely to happen, but im happen that it wont ever be a problem. I like John's suggestion lol.
Andy could use G4YCH47637 for his.
D4VE
Member #: 10749
lowestoft suffolk
Hahaha... what a brilliant new game!!
Im gonna make my engine weigh 100kg less than it is by stamping my block 'G3NU1N3' *tongue*
For Simon:- 8U779LU6
