| Home > Help Needed / General Tech Chat > Digital Dash | |||||||
9th Feb, 2016 at 08:52:49pm
Anyone had a dabble with one of these before?
Edited by MikeRace on 9th Feb, 2016. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Feb, 2016 at 10:38:30pm
Had one in my watch list for a while but that's as far as I got On 20th Oct, 2015 Tom Fenton said:
10th Feb, 2016 at 10:42:25am
That looks pretty good. In the 13's at last!.. Just |
10th Feb, 2016 at 10:58:59am
Could make your own night-rider dash. If something is worth doing, it's worth doing half of. |
10th Feb, 2016 at 11:06:22am
Im not sure of the dimensions but maybe a steering wheel mounted dash system! Could have the mounts laser cut from ally that integrated into the steering boss. Only problem then is wires. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
52 Posts Member #: 11169 AKA: Smegmium Derby, ish |
10th Feb, 2016 at 07:11:54pm
rather expensive tbh...
"If its not broke, whack a turbo on it"
10th Feb, 2016 at 09:31:23pm
Would probably work well for something a bit more modern with a proper enclosed instrument cluster with an engine conversion, new digital innards to the original binnacle. On 26th Jan, 2012 Tom Fenton said:
11th Feb, 2016 at 09:03:30am
On 9th Feb, 2016 MikeRace said:
Anyone had a dabble with one of these before? Not that particular make but I am using similar 7 segment multi digit LED displays for all my AFR and LSU temperature displays, and intend to extend my setup to use them for things like oil presure and water temperature. Personal opinion, but I think the "digital" displays are great - and a lot more compact provided they aren't stuck in a space wasting 52mm round enclosure like lots of manufacturers do - but only for certain things. I would still stick with an old fashioned moving "needle on dial" for speed and RPM. Granted they can be mimiced on a full LCD/LED display panel but I don't think rows of LEDs in a circle is anywhere near as good. That kit does seem a bit pricey for what you get, especially as it isn't new ("re-manufactured" reads "second hand" to me) but obviously the price isn't helped by the postage, import duty and the current exchange rate. Also it looks like imperial readings only, no mention of being able to swap to metric. Whilst I could probably live with oil pressure in PSI I simply couldn't deal with any temperature in Farenheight. But, like I said, personal opinion. Schrödinger's cat - so which one am I ??? |
11th Feb, 2016 at 03:42:07pm
On 10th Feb, 2016 MikeRace said:
Im not sure of the dimensions but maybe a steering wheel mounted dash system! Could have the mounts laser cut from ally that integrated into the steering boss. Only problem then is wires. You'll need to modify a rotary coupler to fit. Get one from a car with steering wheel controls. In the 13's at last!.. Just |
