| Home > Help Needed / General Tech Chat > Wiring in auxiliary water pump | |||||||
23rd Feb, 2016 at 06:11:54pm
Hi
My build thread..
23rd Feb, 2016 at 06:30:11pm
I'd have the circuit wired up using a relay, so that it disconnects power to the pump whilst the ignition is on, and switches it to the live feed with ignition off. Easily done with the correct relay. On 26th Jan, 2012 Tom Fenton said:
23rd Feb, 2016 at 06:52:32pm
Could you put a link up Carl?
My build thread..
23rd Feb, 2016 at 09:09:09pm
Just something like this mate, http://www.autoelectricsupplies.co.uk/mobi...174/category/36
23rd Feb, 2016 at 09:25:21pm
Thanks for that carl very helpful!
My build thread..
24th Feb, 2016 at 05:44:16am
I'd keep the fan seperate, otherwise you'll have the pump running when you turn the fan on, which you might not want if the car is running, although it might be okay I'd rather not risk it myself. You could loop off the fused feed and loop the earth and have the relays side by side, cutting down wiring mess,just make sure the wiring is of adequate size tobrun both the fan and pump. On 26th Jan, 2012 Tom Fenton said:
24th Feb, 2016 at 11:19:41am
Thanks carl
My build thread..
24th Feb, 2016 at 03:50:19pm
Yeah, a timed relay for the rear screen wouldn't be a bad idea, Youd probably only want about 2-3 minutes of water pump time after shutdown at the very most, with the fan on for only as long as it needs to be, id would probably use the switchover relay, implementing a water temp switch to control both the fan and the pump, and possibly also via a timered relay set to a few minutes as a failsafe incase the switch fails closed, draining the battery On 26th Jan, 2012 Tom Fenton said:
24th Feb, 2016 at 05:19:14pm
Something like this?
My build thread..
24th Feb, 2016 at 06:13:30pm
Yeah, just as long as 12a is enough to power the pump and fan, or fit two, one per item so long as the fan is less than 12a draw On 26th Jan, 2012 Tom Fenton said:
24th Feb, 2016 at 06:28:01pm
Excuse my ignorance but what benefit do you think you will get from the additional pump? Depending on position, all i can see is a risk of cavitation in the mechanical pump (my views are simply gut thoughts with no particular science or knowledge to support mind!) |
24th Feb, 2016 at 06:50:40pm
The leccy pump will only be on after engine shut down.
My build thread..
![]() 489 Posts Member #: 9159 Senior Member Devon |
24th Feb, 2016 at 09:09:20pm
What pump have you gone for? i had a similar idea and got the pump but wasn't sure if it'd be man enough to work. |
24th Feb, 2016 at 09:09:23pm
double post.. Edited by jamestar on 24th Feb, 2016. |
24th Feb, 2016 at 09:35:35pm
That makes sense
On 24th Feb, 2016 JT said:
The leccy pump will only be on after engine shut down. I'm running a gt17 turbo which is water cooled aswell. So in order to prevent the water boiling in the turbo after shutdown the leccy pump will kick in to pump water round the engine. I think most production water cooled turbos have this system in place to pro long the life of the turbo. |
24th Feb, 2016 at 10:21:56pm
It wouldn't be difficult to wire this up so that the pump runs when the fan runs, but only when the ignition is off. |
25th Feb, 2016 at 12:12:55pm
What model pump is it? Are you mounting it inline with the mechanical pump or in parallel? Edited by PhilR on 25th Feb, 2016. |
25th Feb, 2016 at 01:48:49pm
http://m.ebay.co.uk/itm/BOSCH-universal-au...d=1486045550018
My build thread..
25th Feb, 2016 at 01:56:03pm
Circulating water in that way means that it wouldn't pass through the radiator, id try and take from the engine and put back into the top of the radiator or the thermostat housing with a sandwich plate. On 26th Jan, 2012 Tom Fenton said:
25th Feb, 2016 at 03:16:08pm
Maybe this is a necessary precaution on a Mini, but on my car I have only once had the water boil in the turbo and that was after 6/7 laps of Cadwell.Convection usually takes care of it but maybe I shut down too early.
25th Feb, 2016 at 03:26:41pm
As Dave says I normally let the engine idle after running and then let the fan run to it turns off.
25th Feb, 2016 at 09:45:33pm
My build thread..
