| Home > Help Needed / General Tech Chat > gearbox disaster! what caused this | |||||||
9th Sep, 2005 at 06:54:45pm
running 10psi boost top gear around 60mph BANG! Edited by BENROSS on 9th Sep, 2005.
9th Sep, 2005 at 07:08:19pm
cracks in the roots of the teeth...?
AlexF |
9th Sep, 2005 at 08:10:09pm
could well be alex one weak one & then the domino affect with the rest
9th Sep, 2005 at 09:01:02pm
Cracks in the root of the teeth is barely an acceptable answer for the overall failure - but this is a strange place to see a failure, after all the Headset ratio is only seeing what, 1.2, maybe 1.3 times engine torque... If it was to go anywhere, it would normally be on 1st, 2nd or 3rd.
9th Sep, 2005 at 09:23:53pm
cheers dave i will pull the gears, clean inspect & try further to find the route cause
271 Posts Member #: 653 Advanced Member Cambs |
9th Sep, 2005 at 10:23:27pm
Get sc mate if you can take the noise. Its only a bit of metal. If it blows it blows!
10th Sep, 2005 at 12:45:04am
I got one that looks like that
10th Sep, 2005 at 09:04:48am
ive seen it quiet a few times on helicals on a powerfull motor or when you do a lot of quick starts.
10th Sep, 2005 at 04:59:28pm
Depends on how much power you want mate. Its only a bit of metal. If it blows it blows!
10th Sep, 2005 at 05:47:54pm
miniwilliams hasnt got one aND NEVER HAD A PROBLEM WITH THE IDLER YET AFTER EN YEARS OF TRYING.
10th Sep, 2005 at 06:14:45pm
O dear Ben very sorry. theres always some thing for more expense!
Edited by Miniwilliams on 10th Sep, 2005. Best 1/4 mile 13.2 seconds @116 mph
10th Sep, 2005 at 07:31:24pm
I was told that the A+ with its larger bearing is fine, its more of a problem with the smaller A series bearing?
10th Sep, 2005 at 11:03:44pm
The straight cut drops are fine!
10th Sep, 2005 at 11:12:42pm
Heres mine
11th Sep, 2005 at 10:22:31am
Dangerous that says it all buddy
11th Sep, 2005 at 03:59:18pm
that input gear takes all the grunt and they will brake as sure eggs will.
10 Posts Member #: 676 Member |
11th Sep, 2005 at 06:24:15pm
this happened to me too. check the box where the first motion bearing sits mine was cracked through to the top of the box |
11th Sep, 2005 at 07:00:27pm
i know which direction iam going to go
11th Sep, 2005 at 07:09:34pm
Ben, if there's anything I can help with give me a shout, have got plenty of shims etc at the moment from when I built my 'box........
11th Sep, 2005 at 07:11:06pm
ive got a spare a+ 998 box as well for free |
11th Sep, 2005 at 07:18:09pm
Look at it this way, if you get the cheaper drops and they break then you'll want to get the roller one anyway and you'll end up buying twice. Might be cheaper in the long run to get the rollers?
11th Sep, 2005 at 08:17:57pm
you are quiet right 300 when the tyres spin the relieve the whole box but its when you are in the higher gears you still have all that tourque still loading through the box especially when you are travelling at speed you also have to counteract the airodynamics of a brick eg the mini and the engine is pushing all the torque and hp through it trying to push it foward.
11th Sep, 2005 at 08:22:55pm
On 10/09/2005 00:45:04 Dangerous said:
I got one that looks like that If you were in top at the time why the layshaft and input gear ?? 4th still worked on mine but the rest never
As above. 4th gear locks the mainshaft, so you arent actually driving through any gears as such ( apart from drop gears ) I'd say the breakage happened in a lower gear, but just didnt become apparent unitl you shifted to 4th for some reason ? Every A+ box I broke was exactly like that. I stripped about 4 boxes before I finally went with a Tran-X straight cut gear set. It usually happened when overtaking in 3rd gear. Ive only broke one Tran-X, stripped 2nd gear. Ive never stripped or damaged the helical drop gears. I also think from my brief readings here, not too many have either. At least with them 4th gear cruising is quiet. Edited by stevieturbo on 11th Sep, 2005. 9.85 @ 145mph
12th Sep, 2005 at 08:57:28am
"On that note, will your drops hold up if you fitted an LSD and maybe some gripier tiers miniwilliams?
12th Sep, 2005 at 12:16:59pm
thanks tom and iain for the offers
