Home > Help Needed / General Tech Chat > Megajolt Trigger Wheel Fitting
minix
Member #: 2236
I just stated to fit a megajolt over the weekend, what crankshaft damper is fitted as standard metro turbo, the VR unit is at the end of its mounting bracket & has no adjustment and is only just, it seems to me that a thinner damper is require to allow the VR sensor to be in the centre of the trigger wheel. I don't really want to got eh the expense of a MED damper any other OE ones that will fit.
Thanks
What damper and bracked do you have?
Anyway use washers to line it all up
Mine needed 2 or 3per bolt
As Brett says, space the bracket out a little
minix
Member #: 2236
Thanks , the damper is the OE part that was fitted to the Metro Turbo & the VR bracket is the one that came with the kit, which with the spacer fits the timing cover well. If add further spacers/washers to move it out then the electrical connection looks like it will clash with the subframe !, I'll take picture and maybe somebody can tell if its the correct damper. It has TAM 1241 stamped on the inside face.
Regards
More to the point, what trigger kit are you using?
Yes, the crank sensor boot touches the subframe, presuming this is a trigger wheels kit, hasn't caused a problem but try and rotate it as much away as you can.
PhilR
Member #: 10034
Birmingham
I have a metro one here and yes, it's a bit wider than the mini ones.
If you don't want to modify the bracket, just get one off a mini.
minix
Member #: 2236
Ok thanks, I'll shim out the VR sensor until it has full coverage of the trigger wheel, & see how much of a clash there is with the wiring & the sub frame and go from there.
e5tus
Member #: 10128
Dorset
I had the same issue, took a hole saw to the subframe where the clash was
