| Home > Help Needed / General Tech Chat > Turbo build... Experience needed | |||||||
12 Posts Member #: 8957 Member Chorley, Lancashire |
4th Mar, 2016 at 09:22:20pm
Pretty new to the turbo scene.
4th Mar, 2016 at 10:22:53pm
You don't need to created power with high RPM, so no need for balanced conrods or ARP rod bolts. Use standard A+ rods and get the clutch balanced though.
Edited by PhilR on 4th Mar, 2016. |
4th Mar, 2016 at 10:40:10pm
Thanks Phil
On 4th Mar, 2016 PhilR said:
You don't need to created power with high RPM, so no need for balanced conrods or ARP rod bolts. Use standard A+ rods and get the clutch balanced though. Cross pin differential is a must. The rest of the gearbox should be good for roughly 130 hp, if it's in good condition and you're kind to it. The rest of the list looks sensible, but you now need to pick a power figure, estimate your boost, decide on compression ratio then build your spec to this. |
5th Mar, 2016 at 09:43:35am
Looks like a decent spec for 150hp and a bit more,
5th Mar, 2016 at 12:17:51pm
BHP: estimate the power you'd get if your engine was NA - I'd guess around 90. You'd have to multiply that number up by another 66% to get 150, so you'll need 66% more air. An NA engine consumes air at an atmospheric pressure of 1Bar so boost needs to provide the extra 66%... So thats 0.66Bar (or 10 psi).
Edited by PhilR on 5th Mar, 2016. |
5th Mar, 2016 at 06:43:18pm
On 5th Mar, 2016 PhilR said:
BHP: estimate the power you'd get if your engine was NA - I'd guess around 90. You'd have to multiply that number up by another 66% to get 150, so you'll need 66% more air. An NA engine consumes air at an atmospheric pressure of 1Bar so boost needs to provide the extra 66%... So thats 0.66Bar (or 10 psi). For several reasons, that's only an estimate. I'd imagine 9 to 12 psi should get you close. If your intercooler does its job and your MegaJolt and fueling are set up well, 9.8:1 CR sounds good to me. I'd personally make a habit of only using higher octane petrol. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Mar, 2016 at 08:27:36pm
Blimey, no! (Was thinking about 98RON while typing)
5th Mar, 2016 at 09:28:47pm
Sweet baby Jesus... That has just filled with even more dread...lol |
5th Mar, 2016 at 09:44:30pm
As above but if you want a very smooth engine its well worth getting. The whole rotating assembley balanced I.e. flywheel ,clutch back plate and crank pulley, crankshaft, its a pleasure to drive sutch a smooth powerful Engine Edited by BENROSS on 5th Mar, 2016.
