| Home > Help Needed / General Tech Chat > Stereo Noise From Wideband O2 | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
11th Mar, 2016 at 04:56:01am
I just installed my Innovate MTX wideband and I'm getting a buzzing noise from my dash mounted speakers. I'm using a small Amp also located in the dash area. I've tried a ton of things and can't seem to eliminate or change the noise. If I unplug the gauge the noise goes away so I'm pretty sure I've narrowed it down to that
11th Mar, 2016 at 07:05:36am
What's your audio source? Was it plugged in during your testing? |
11th Mar, 2016 at 07:13:48am
Audio source is RCA->3.5mm cable to my phone or iPod.
11th Mar, 2016 at 08:39:07am
When you say "If I unplug the gauge the noise goes away" do you mean unplugging the power to the gauge or unplugging the LSU (sensor) cable from tha gauge ?
11th Mar, 2016 at 08:39:38am
I'd suspect noise due to the PWM switching of the sensor's heated circuit being injected onto the power wires... But you've pretty much already tested that thoroughly.
11th Mar, 2016 at 09:46:31am
Following up on Phil's point about the noise could easily be being carried by the power wires (rather than the grounding) - with which I agree entirely - how are they both powered ?
11th Mar, 2016 at 04:50:00pm
On 11th Mar, 2016 PhilR said:
I'd suspect noise due to the PWM switching of the sensor's heated circuit being injected onto the power wires... But you've pretty much already tested that thoroughly. Does the tone or volume change in the first 30 seconds, as the sensor's heater ramps up? Any estimate of the frequency? As a test, have you tried putting them on completly different batteries? Does the noise increase when turning up the amp's volume control? Yeah the noise changes a bit as it goes along and then it settles into switching between a couple different frequencies. I only have gain control on the Amp (use input device volume for control) and that seems to barely if at all effect the noise. Moving the wiring to direct from the battery definitely decreased the sound but not eliminated it. Sounds like the noise isolator and a totally fresh, separate circuit are in order. Thanks for the help, hopefully this sorts it |
11th Mar, 2016 at 06:08:27pm
I may be replacing my head unit with a small amp like that, so would be interested in how effective any power filters are. Let us know how you get on? |
11th Mar, 2016 at 09:56:26pm
Can't you fit an interference suppressor? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Mar, 2016 at 03:05:13am
Got the noise to a point that I'm happy with after this weekend.
