Home > Help Needed / General Tech Chat > metro cam timing.
Rammie2000
Member #: 10190
belgium
So... as i was membring around the garage i found a non adjustable twin timing set...
I can be death wrong here but doesn't that set the came timing at 107°?
Edith... just realised that this twin set is the one from the 998 i have to rebuild for my neece..
. so extra question out of intrest ... : if i check timing with this one or in fact any timing set and see it needs a timing key... would it be the same timing key on every sprocket set ( on the same cam of course )
And the metro cam needs to be timed in at 107.5° so give the chain some strech and thats about where i would end up right?
Or am i just looking at it the wrong way?
If im right i just need an oilpump and i can start the engine build.
As an extra. How do i check if the vibration damper is still good?
Grts
Edited by Rammie2000 on 12th Mar, 2016.
slater
Member #: 1291
Suffolk / Birmingham
The sprockets are not that accurate so you need to fit them. Check the timing and then select the right key.
slater
Member #: 1291
As for the damper check there are not cracks in the rubber. The rubber needs to still be soft.
I've always timed my MG metro cams in at 110.
