| Home > Help Needed / General Tech Chat > rover k-series, on boost afr what should I look for | |||||||
14th Mar, 2016 at 09:57:39am
After searching g around d I have confused myself a bit, what is a sensible afr to run while on boost, I know the a-series requires 11ish afr to be safe but can I run 12-13 and still be safe? Drives
14th Mar, 2016 at 10:26:26am
well, depends on how much boost really,
14th Mar, 2016 at 11:53:28am
13 too lean imo
Yes i moved to the darkside |
14th Mar, 2016 at 02:04:17pm
I should add the water meth doesnt really lower aits because i have an intercooler 2 foot wide 1 foot tall and nearly 4 inch thick.. and its well duckted hahaha Yes i moved to the darkside |
14th Mar, 2016 at 03:09:25pm
On 14th Mar, 2016 Brett said:
and its well duckted hahaha You're quackers. If something is worth doing, it's worth doing half of. |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
14th Mar, 2016 at 04:47:12pm
i have an intercooler 2 foot wide 1 foot tall and nearly 4 inch thick.. and its well duckt taped hahaha
You sure do like using that stuff in/on your motors dont ya... Edited by D4VE on 14th Mar, 2016. On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
14th Mar, 2016 at 04:53:22pm
I always aimed about mid to high 11's leaner could cause a little det around peak torque, could be leaned off after that point but I never did just to be safe. up to a bar of boost im sure low 12's would be perfectly fine, you know how it is though, every engines different :) Non turbo I seem to recall aiming for high 12:1. numbers just a number tho (as you know) I was fortunate to have acces to a tail-pipe wideband as well as my built in wideband so could occationally confirm they matched up. while the one on my car always seemed to hold true, the one we put on the tailpipe fitting would need replaced every 10 tuning sessions or so, it would wander out of spec, I presume because the heater in it was having to work extra hard. long and short (and i know youll know this but handy to have it written down!) dont trust other peoples ideal tuning numbers! turbo 16v k-series 11.9@118.9 :)
14th Mar, 2016 at 08:39:42pm
You sure do like using that stuff in/on your motors dont ya... Twat 😂😂 Yes i moved to the darkside |
14th Mar, 2016 at 11:27:48pm
Cheers guys, main reason for asking is kmaps do a map for the vvc turbo setup, at 11psi it's 11.8, I will be running more boost so obviously will require more fuel to be added so a good "custom" map should do the trick. Drives
15th Mar, 2016 at 07:10:06am
Cobblers. No way of saying what any map will do on any different engine that has different condition fuel pump, injectors, turbo, exhaust system, blah blah blah.
16th Mar, 2016 at 12:02:22am
It is just a generic safe map hence asking, I wanted to have it running sooner rather than later so will be using a rover mems3 before stand alone, a vehicle specific map will be done instead. Latr most likely use an emerald as their ecu can support the vvc setup but cost for tuning I cannot justify for now.
16th Mar, 2016 at 07:18:06am
Anything getting near 11.2 and you'll see black smoke and you might struggle to get a spark under boost Edited by Sprocket on 16th Mar, 2016. On 26th Oct, 2004 TurboDave16v said:
