Home > Help Needed / General Tech Chat > Which Clutch for Mini Turbo?
ian2000t
Member #: 2764
Halesowen
What clutch should I be using for an A+ Verto Mini Turbo setup? It's a daily driver, probably will never see a drag strip, so don't want anything too heavy/snatchy.
Spec's are below - estimate 110-120bhp?
1330 turbo
9:1 compression
GT1752 @ 8-10psi
Intercooler
Benross head
2.76 FD & Minispares cross pin
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
slater
Member #: 1291
Suffolk / Birmingham
Cant fault an RTS 'double spring' setup.
Search RTS and all is well covered on here.
ian2000t
Member #: 2764
Halesowen
Just had a look. Not really confident in my abilities to do that in all honesty. Unless someone sells these as kits?
What off the shelf solution would be best?
slater
Member #: 1291
The only real option off the shelf for a verto is a light blue 'turbo' cover and a race/rally plate.
Id be happy to build you an RTS tho if you can source the bits. You basically need two AP covers. (998 'green' ones would be best).
for 120 hp you should be ok with a blue turbo cover and a rally fiction plate.
IMO vertos are much smoother/ predictable etc
ian2000t
Member #: 2764
Halesowen
Will probably go for the blue turbo cover then, but thanks for the offer Slater - may well take you up on that if the blue doesn't seem to hold up.
Do you mean this kit?
http://www.minispares.com/product/Classic/GCK371AF.aspx
Or, do you mean using the clutch cover from that:
http://www.minispares.com/product/Classic/....aspx|Back%20to
But with something like this:
or..
ian2000t
Member #: 2764
Halesowen
Actually, I think I've found the one you mean:
So, this cover:
And this plate:
https://www.minispares.com/product/Classic/C-AHT596.aspx
adcyork
Member #: 6807
York
So, this cover:
And this plate:
yes
ian2000t
Member #: 2764
Halesowen
Thanks guys!
Shaunas has an AP race/rally friction plate and the 'turbo' pressure plate, doesn't slip at 10psi/117ftlbs and I doubt it would at 12-14psi although that's probably closer to it's limit at around 14-15 I'd have guessed.
e5tus
Member #: 10128
Dorset
With my verto setup I used the AP race/rally plate and the turbo cover, fine at 7psi, but slipped when I turned it up
ian2000t
Member #: 2764
Halesowen
What power/torque figures were you getting from 7psi?
jonny f
Member #: 9894
Dorking
I put 101.4 bhp and 90lbft through the turbo verto clutch. No bother at all. Non turbo though at that time.
Honestly RTS is fairly simple and if slaters offering it to you I would recommend taking him up on it. It'll be worry free pretty much.
e5tus
Member #: 10128
Dorset
101hp and 116lbs/ft (Printout half way down http://www.turbominis.co.uk/forums/index.p...id=498679&fr=50 )
We tried to turn the boost up at Slark's but it slipped, so kept it at 7psi until I upgraded.
