| Home > Help Needed / General Tech Chat > RTS slips at 10psi | |||||||
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
30th Mar, 2016 at 07:27:28pm
Only done 1700 miles, RTS AP type made from a 1275 spring and a turbo spring, AP rally plate 180mm. MED steel flywheel. Full weight car on a 2.9 final drive. Now slipping in 3rd and fourth at 10 psi
31st Mar, 2016 at 06:48:11am
Are the springs almost flat when all bolted up?
Yes i moved to the darkside |
31st Mar, 2016 at 09:16:04am
Springs are almost flat. However maybe they could be flatter to increase the clamping force a little? How can i do this?
31st Mar, 2016 at 10:00:36am
My RTS has a low biting point but it's quite progressive. If something is worth doing, it's worth doing half of. |
31st Mar, 2016 at 10:14:07am
that dosent look that flat to me,
31st Mar, 2016 at 06:51:58pm
Looks like that's hardly clamped up at all.
31st Mar, 2016 at 10:49:12pm
Should look like this
1st Apr, 2016 at 05:08:49pm
Isn't it the length of the spacers that is crucial in making it clamp down flat? |
1st Apr, 2016 at 05:38:47pm
nope, spacers are determined by the thickness of the springs On 28th Aug, 2011 Kean said:
1st Apr, 2016 at 06:51:07pm
Ive been staring at this for two days now.
1st Apr, 2016 at 06:54:55pm
Also after reading roberts clutch thoughts thread, page 4 says after the clutch wears slightly the clamping force increases a bit. The pictures on page 4 are not there any more so im having difficulty understanding this point too if anyone can enlighten me cheers |
1st Apr, 2016 at 08:37:30pm
But what happens if they are too big?
On 1st Apr, 2016 Joe C said:
nope, spacers are determined by the thickness of the springs |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
1st Apr, 2016 at 08:43:21pm
I read it 20 times now and i think it has to do with the springs beeing pulled against the pressure plate with the bolts. So it clamped harder. That moment you don't puch the springs down against the cranck so it has no difference in to that If they are to big the springs sit to loose i think. But by far a specialist.. aqtualy Try to figure it out by myself but to luch time on my hands and toughts to forget not to answer this. you can do anything if you set your mind to it...
1st Apr, 2016 at 10:18:35pm
Take it appart and take pictures as you do, as i think its not been assembled correctly. There is far too much discrepancy for it to be anything else On 26th Oct, 2004 TurboDave16v said:
2nd Apr, 2016 at 08:18:30am
On 1st Apr, 2016 dazibee said:
Ive been staring at this for two days now. Please correct me anywhere i am wrong here because i am probably making assumptions.... Is it true that to make the spring sit flatter i either need a thicker clutch plate or would need to mill a little metal off my flywheel pedastals? I have been playing around with a drill press and a dial gauge. With my clutch setup as it is, dial gauge on the outer part of the spring, and pressing down the centre with the drill press to release the clutch, as soon as i apply pressure to the centre i get a corresponding upwards deflection at the outer edge of the spring, meaning it is beginning to release. What i cant understand is how can making the spring flatter can increase the clamping force, please could someone explain how this works cos i dont get it. Cheers It's really very simple. Your diaphragm spring is in no way at all clamped up. There is no load from it, it is barely putting any pressure on the friction disc. it's like an uncompressed spring. rest your finger tip on the table....there is no pressure being applied to the table. Now push really really hard. Your finger will try and straighten/level out the more pressure is applied. It's the same thing Whilst yes a thicker friction disc would achieve more clamp....unless you have completely the wrong type of disc in there, you have assembled the RTS clutch incorrectly. 9.85 @ 145mph
2nd Apr, 2016 at 09:39:02am
On 1st Apr, 2016 Sprocket said:
Take it appart and take pictures as you do, as i think its not been assembled correctly. There is far too much discrepancy for it to be anything else |
2nd Apr, 2016 at 09:40:14am
Final pic |
2nd Apr, 2016 at 09:42:14am
Ive been staring at this for two days now. Please correct me anywhere i am wrong here because i am probably making assumptions.... Is it true that to make the spring sit flatter i either need a thicker clutch plate or would need to mill a little metal off my flywheel pedastals? I have been playing around with a drill press and a dial gauge. With my clutch setup as it is, dial gauge on the outer part of the spring, and pressing down the centre with the drill press to release the clutch, as soon as i apply pressure to the centre i get a corresponding upwards deflection at the outer edge of the spring, meaning it is beginning to release. What i cant understand is how can making the spring flatter can increase the clamping force, please could someone explain how this works cos i dont get it. Cheers It's really very simple. Your diaphragm spring is in no way at all clamped up. There is no load from it, it is barely putting any pressure on the friction disc. it's like an uncompressed spring. rest your finger tip on the table....there is no pressure being applied to the table. Now push really really hard. Your finger will try and straighten/level out the more pressure is applied. It's the same thing Whilst yes a thicker friction disc would achieve more clamp....unless you have completely the wrong type of disc in there, you have assembled the RTS clutch incorrectly. |
2nd Apr, 2016 at 10:18:33am
The spacers are probably too long.
2nd Apr, 2016 at 10:39:33am
Just checked the spacers, they are cock on. Spacers are 435thou which is the thickness of my two rings and two springs added together
On 2nd Apr, 2016 slater said:
The spacers are probably too long. |
2nd Apr, 2016 at 11:15:54am
It should be the thickness of the original spacer from the clutch plus the thickness of whatever spring you add in.
2nd Apr, 2016 at 11:28:10am
Now assumining it was all built correctly....... Let me know if it wasnt.
2nd Apr, 2016 at 11:48:43am
The problem will be with your spacers.
Edited by stevieturbo on 2nd Apr, 2016. 9.85 @ 145mph
2nd Apr, 2016 at 12:29:29pm
Right.... spacers....
2nd Apr, 2016 at 01:02:08pm
I tried a different backplate and the lugs are identical in height. I will mill the flywheel pillars i think.
