| Home > Help Needed / General Tech Chat > modifying the front arch and exhaust questions | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
31st Mar, 2016 at 02:33:47pm
hy. had a search but probably didn't find the proper words.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
31st Mar, 2016 at 03:54:41pm
Round bar with a 10mm slot in it... and finish off with some panel beating hammers (cant think of the right word.. would just say dollies but dont want to annoy the ali wizard On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
31st Mar, 2016 at 04:08:23pm
the sportspack cars had a stiffener welded to the arch; I'm note sure how appropriate they would be depending on the arch choice but I suppose something could be made up to reflect your requirements
31st Mar, 2016 at 05:36:03pm
ha ha yes dont say dolly's i made that mistake.
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
31st Mar, 2016 at 06:34:21pm
Thats kinda how I tubbed my rear arches, a short section of bar, around 8-10mm diam. 1mm cutting disk down the middle about 10 mm or so deep (the 10mm slit in the bar stops you trying to bend off too much material), then after you have parted off the unwanted metal, slowly go back and forth over the lip making sure not to try bending it too much at once . Doing so will expand the metal too much and will give it a kink by the time you have got the lip at 90degrees.
David. |
31st Mar, 2016 at 08:09:52pm
With regard to the exhaust, it would be quite loud as the silencer would have to be quite small to fit in place. The bigger issue would be that the EGTs would be very high that close to the turbo, so the packing in the silencer may not last all that long? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Apr, 2016 at 03:21:32am
Thnx for the input. The bar is kinde as i imagined. But indeed needs to be a full bar.
