Home > Help Needed / General Tech Chat > Fuel line sizes?
ian2000t
Member #: 2764
Halesowen
I've currently got 8mm OD feed, and 6mm OD return lines. Is this OK for a turbo setup?
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
the return should in theory be larger than the feed, although some have the same size.
Personally i'm running 8mm OD supply and 10mm OD return
ian2000t
Member #: 2764
Halesowen
Not that I disagree, but why would the return be larger than the feed? Surely it will always be flowing less than the supply will?
it is to ensure there is no pressure build-up that could affect the performance of the regulator
Same size for both will be fine. I wouldnt do big feed small return for the reasons Rob says.
Unless lines are too small to begin with, dont think there's any need to do return bigger than feed.
Shauna
Member #: 10424
Swansea boyo!
Both my feed and return are 8mm
slater
Member #: 1291
Suffolk / Birmingham
I ran mine like that years ago and it worked fine but it's not ideal.
10mm is OTT in my opinon. 8mm is more than enough.
Both mine are 8mm
8mm is enough to feed both of the 2 most powerful a series on here
thats why mine are 10mm lol
ian2000t
Member #: 2764
Halesowen
OK, cheers, I'll go with both 8mm OD.
mini93
Member #: 2017
Warwick.
Are people talking about 8mm OD?
If so, what diam' braided fuel lines are people using?
Fuel tanks I have been looking at have -6 AN threaded inserts fitted, but this being 9.5mm is a lot larger than what most people here are running.
David.
JT
Member #: 637
Hertfordshire
I've just done mine.
I used 8mm (od) copper fuel pipe and 8mm (id) braided hose.
The mpi tank has 8mm feed and return as does the fuel filter I'm using and the fuel regulator. The carb is 6mm feed, so I can't see it being too restrictive...time will tell I suposse.
Josh
My build thread..
Tube is usually measured in OD while hose is measured on ID
Pipe is another ball game altogether lol
PhilR
Member #: 10034
Birmingham
7mm feed and return on mine (Because someone at Rover thought it would be a great idea to make the SPI with an odd-ball size).
At 15 psi, flow rate is enough for 250bhp.
Nick
Member #: 154
Midlands
Dave, just plumbed all mine in -6, looks like it should be fine for the job
mini93
Member #: 2017
Warwick.
Splendid, thanks Nick.
I can get more of my crap ordered soon then.
David.
