| Home > Help Needed / General Tech Chat > Having trouble fitting up my SD 6 point bolt in cage. | |||||||
17th Apr, 2016 at 05:46:28pm
Been trial fitting my safety devices 6 point in today, getting the 3mm spreader plates in position to be tacked up, and having massive problems getting the rear cage feet into position.
17th Apr, 2016 at 06:56:53pm
I was most likely doing it worng but I started with the rear feet first.
17th Apr, 2016 at 07:07:52pm
The last cage I had, no idea who made it, but it dropped straight in all 4 feet no worries, just needed the rears pushing out a bit, but was only acrear cage so I sold it. This is terrible to fit, I think it's having the front cage on aswell which makes it much less maneuverable. Worst case I'll just weld the holes up and try going back to front. On 26th Jan, 2012 Tom Fenton said:
17th Apr, 2016 at 07:10:35pm
Should be an easy fix as your welding in the plates anyway I have started posting on Instagram also my name on there is turbomk1golf
17th Apr, 2016 at 08:48:44pm
Bigest problem i found with fitting the rear cage is that there is a 3/8" discrepancy side to side in the dimensions of the shell. The drivers side rear wheel well sits a little further back On 26th Oct, 2004 TurboDave16v said:
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
17th Apr, 2016 at 08:55:14pm
I also fixed the rear cage in first in mine, had to jack out the rear legs aswell....
the pissed up clown stood back up, did a twirl and left bollock naked, |
![]() 359 Posts Member #: 8931 Senior Member Herefordshire |
18th Apr, 2016 at 03:55:37pm
I agree with what's been voiced above.
18th Apr, 2016 at 06:07:53pm
Thanks for the advice all, I'll have another crack at it soon with a clear mind and let you know how I got on, the pictures would be highly appreciated Billus, thanks. On 26th Jan, 2012 Tom Fenton said:
2nd May, 2016 at 05:57:07pm
Fresh look at it definitely helped loads, finally got it sitting in place, window packers have a multitude of uses! On 26th Jan, 2012 Tom Fenton said:
10th May, 2016 at 08:49:59pm
Mine was exactly the same, a right shit job. |
![]() 552 Posts Member #: 300 Post Whore Cumbria |
15th May, 2016 at 05:51:06pm
mine too, i had the rear arches built up towards the feet to neaten it up.
Here for the craic..
