| Home > Technical Chat > Turbo fuel regulator | |||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
12th Sep, 2005 at 09:07:23pm
I've got myself a turbo regulator for my SPI tank and pump, i've bought it so i can get my car running again in the short term with a nat asp engine whilst i save up for my turbo build. However im a bit unsure what i need to connect up to the regulator. 3 of 4 connections are obvious, the feed and return to the tank already have all the plumbing in place. The carb feed is similarly sorted, but im unsure about the 'boost' lug, what does that need to be connected up to? Someone suggested since im running it for a nat aspirated car for now that i need to vent it to air? Is that right and do i need to change it when i turbo it I've seen the future and tbh its Pie
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
12th Sep, 2005 at 09:12:07pm
you should just be able to leave it if you are running na as it is pressure from the plenum that goes into the fuel regulator to let more fuel in so in essence just leave it or maybe just block it off with a bit of fuel hose and a nut in the end to stop dirt geting in there "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
12th Sep, 2005 at 09:12:41pm
leave it vented to air while running NA then it just needs connecting up to the plenum when running turbo |
