| Home > Help Needed / General Tech Chat > Oil Filter Seal Blowing | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
20th Apr, 2016 at 03:19:15am
Well this stinks!
Edited by seahuston on 20th Apr, 2016. |
20th Apr, 2016 at 04:40:54am
Have you plugged and redrilled any of the holes on the underside of the block while having it apart? Possibly plugged the oil return hole? A so called professional engine guy here in Norway did that once, and it caused exactly this behaviour. |
20th Apr, 2016 at 04:52:54am
Here's a shot of my block before I assembled it, looks like the drain hole is clear:
20th Apr, 2016 at 05:17:57am
Update!
20th Apr, 2016 at 08:00:02am
This is all character forming and helping you to bond with your car. |
20th Apr, 2016 at 08:09:10am
Good learning :).
20th Apr, 2016 at 08:34:38am
Glad you found it, I have had a similar problem before with excess oil pressure, it seems the filter seal is the weakest point.
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
20th Apr, 2016 at 02:17:09pm
I have a block in my garage which does exactly the same thing. It turned out to be a factory brass plug fitted in an oilway just behind the relief valve preventing it working. Think the block came from an inline engine |
20th Apr, 2016 at 02:30:29pm
that is a jolly interesting section, I never realized the main beaing gallery and oil relief valve intersected,
20th Apr, 2016 at 02:34:17pm
mind you that appears to be a a small bore block judging by the start of a tapet chest and 1 core plug. On 28th Aug, 2011 Kean said:
20th Apr, 2016 at 06:31:35pm
On 20th Apr, 2016 Joe C said:
that is a jolly interesting section, I never realized the main beaing gallery and oil relief valve intersected, IIRC there is somthing in the Vzard book about some blocks not having the relief vaolve seat fitted... and hence no oil pressure. ![]() |
20th Apr, 2016 at 06:45:59pm
Here is the block diagramed as I understand it.
20th Apr, 2016 at 07:09:32pm
Make it parallel, it then is a fit along its whole length which will be sufficient to retain it. Make it tapered and it will only be a fit in one spot around the plug.
21st Apr, 2016 at 03:43:58am
Solved! Knocked up a plug for it today.
