Page: |
Home > A-Series EFI / Injection > Wet Manifold and Typhoon Assistance | |||||||
186 Posts Member #: 7637 Advanced Member Fremont California |
23rd Apr, 2016 at 10:24:19pm
I know some people have some experience with the Typhoon and after a few months of struggling I need help. My installation is nothing fancy, but required a few accommodations to be installed in a MK I Traveller shell.
4890 Posts Member #: 1775 Post Whore Chester |
23rd Apr, 2016 at 10:50:30pm
Yep if I remeber correctly you need to extend the table, it was a key stroke to edit the table values. I run a supercharger and I don't care the TB is on the wrong side.
23rd Apr, 2016 at 10:56:21pm
Thank you, do you remember what values you added? This is a 4.9 sensor, I would think I could look it up in the specs that have been posted for the 4.9. One would also think the vendor might provide those values, but that is another story too... |
23rd Apr, 2016 at 11:15:40pm
I would ask sc... I run a supercharger and I don't care the TB is on the wrong side.
23rd Apr, 2016 at 11:23:56pm
Asking SC is another part of the story. They were very helpful at the outset, but less so lately. They even connected remotely back in November and made some adjustments, but that was when the narrow band was installed. I thought purchasing the wide band through them might encourage a response, but that has not happened. It has been suggested that I need to call them...as numerous emails are not responded to. I may have overdone it at some point with the emails... Edited by tmsmini on 24th Apr, 2016. |
24th Apr, 2016 at 12:05:08am
Just checked again and while on the Lambda Input page live, I see the voltage fluctuating as well which I think means that even if I had more or different reference points, the sensor output still appears to be fluctuating greatly.
24th Apr, 2016 at 03:16:46am
Unless they have a WBO2 controller with a custom calibration different from what is used on all other 14point7 products, the calibration you initially mentioned is way off. The one in your last post is the one that is used in the normal 14point7 products. And looking at the picture you had sent me, it does look like the standard Spartan 2 which I doubt would have a custom calibration.
6743 Posts Member #: 828 Post Whore uranus |
24th Apr, 2016 at 07:36:51am
maybe take it off closed loop so its not chasing its tail too? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th Apr, 2016 at 12:56:40pm
Why did you swap from the LM-2?
24th Apr, 2016 at 03:46:55pm
I am afraid I have been spinning my wheels so much that I have lost any logic. The whole process was going to be logical and methodical, but I lost that along the way. Probably when I took the suggestion to "just buy" the SC system and get the car on the road.
24th Apr, 2016 at 10:39:23pm
If the AFR readings are not matched by equally poor running, I would suggest pulling the sensor and trying the butane gas to see if the erratic behaviour is a real engine reading or just a wiring issue or a setup or incompatibility issue with all the hardware.
25th Apr, 2016 at 12:12:42am
Good point about the 4.9. I've had a 4.2 controller sent to me by mistake and with a 4.9 sensor connected, the reading was all over the place.
25th Apr, 2016 at 03:40:07am
Good question about the 14point7 controller. I need to check and verify. As the connector is different for the 4.9 sensors I did not think there could be a mismatch. I just bought the 14point7 controller and sensor from SC a few weeks ago.
Edited by tmsmini on 25th Apr, 2016. |
25th Apr, 2016 at 04:03:40am
If anyone wants the SC Typhoon SX-Tune software help documents in a printable format, it is attached.
25th Apr, 2016 at 08:41:40am
On 25th Apr, 2016 tmsmini said:
Good question about the 14point7 controller. I need to check and verify. As the connector is different for the 4.9 sensors I did not think there could be a mismatch. I just bought the 14point7 controller and sensor from SC a few weeks ago. Actually good point by you, as the Spartan has the connector built in it should be the correct match. The 14point7 controllers I (and Jean) use are just modules without connectors so it is possible to get them wrong but the Spartan should be foolproof. I'd try the butane. Whilst I wouldn't be too surprised at a faulty Innovate (I had two fail so started using the 14point7 stuff quite some time ago) I would be surprised at a faulty 14point7 controller but the sensor itself may be at issue. If SC bought if from Alan (14point7) then it's travelled from its place of origin (probably eastern Europe if it is a genuine Bosch) to Cananda, then to the UK, then back to the USA and may have had a few knocks and bumps on the way. From the experience of someone else I know, the 4.9 sensors don't seem to be as robust as the 4.2s Schrödinger's cat - so which one am I ??? |
25th Apr, 2016 at 03:37:19pm
Interesting question about the 4.9 sensors. The one from SC is a D2P, but at least has a sticker on it.
25th Apr, 2016 at 06:33:35pm
The fist 4.2 kit I had from sc was faulty. They never believed me, they said they have never had a faulty one and they test all of them before they leave.... The only way I could get them to return it was by stating that I would post it back, and pay for them to test it and return postage if it wasn't faulty. The upshot I sent it back, I never heard anything and a new one magicked itself In the post.... I run a supercharger and I don't care the TB is on the wrong side.
25th Apr, 2016 at 08:26:16pm
Thanks for that Graham. I hesitated to post due to issues with previous threads on the forum. I had asked about an adapter to make a wideband work with their harness that I am using. Eventually I found on their website store there was a drop down where the MPi style connector could be selected.
26th Apr, 2016 at 07:46:23am
Re. the markings on the 4.9 sensors, back at home I think I still have Graham T's failed 4.9 sensors. I'm still out of the country at the moment and can't remember if I posted them back before I left....
10 Posts Member #: 10968 Member |
26th Apr, 2016 at 09:25:30am
On 23rd Apr, 2016 tmsmini said:
... I initially was trying to use an Innovate LM2 for AFR, but I switched to using an SC provided wideband sensor which is actually a 14point7 controller. This at least allows for the values to be viewed in the same interface. It seems the sensor configuration is not right as the lambda value is bouncing all around. ... I am thinking the Lambda Sensor Input Scaling table is incorrect. It only has two values 0.00 = 0.50 4.45 = 1.50 It almost seems like the wide band acts like a narrow band, maybe when it is in closed loop it does that, going high and low. ... Input 0V ---> means Lambda 0.5 --> 7.35 AFR Input 4.45 V ---> means Lambda 1.5 --> 22.05 AFR The measuring range is between these values. |
26th Apr, 2016 at 03:17:06pm
I sent an email to Innovate and already received a reply. It is out of warranty, but they will evaluate it. I think it has had issues all along and they have just been getting worse. Initially I thought it was due to the use of the tailpipe clamp, as the values were not consistent. Even using the ports in the LCB manifold, the readings were inconsistent. And certainly there was a difference between inner and outer, but that is a different story...
26th Apr, 2016 at 05:30:48pm
The response from the sensor is not linear but the output from the controller is. So you indeed only need 2 values to fully define the output.
26th Apr, 2016 at 06:01:56pm
Thanks Jean.
27th Apr, 2016 at 02:24:31am
Both 4.9 sensors failed the butane test.
2nd May, 2016 at 04:44:55pm
So while I am waiting for the LM-2 to be returned and maybe a response from SC, I plugged the sensor ports and went for a 30 minute drive at speeds up to 50 mph. The car actually drove quite well.
Page: |
