| Home > Help Needed / General Tech Chat > Running lean @low RPM | |||||||
![]() 12 Posts Member #: 9789 Member The Netherlands |
24th Apr, 2016 at 10:29:04am
When I push de pedal from low RPM (from 1000 to 3000) the engine leans out.. I don't have this problem when I push the pedal slowly.. I thought it was the carb oil, but the oil is fine (tried several oils). Before I'm going to adjust the needle; does anyone have an idea/solution for this problem? On the street it's terrible to drive in combination with a grey diaphragm and paddle plate. Above 3500 everything is fine.. @cruising speed AFR is around 14.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
24th Apr, 2016 at 10:33:30am
Welcome... i recolgnise you n the mini from a youthbe vid? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
24th Apr, 2016 at 10:36:25am
Stronger spring in the carb? I run a supercharger and I don't care the TB is on the wrong side.
24th Apr, 2016 at 11:08:05am
Thanks Dave! This one? https://www.youtube.com/watch?v=hUY6QsDFlZk |
24th Apr, 2016 at 11:13:39am
spring or dashpot oil would be first port of call
24th Apr, 2016 at 04:44:07pm
I'd definately try a stronger spring. If you don't have one you can double up two standard ones as an experiment.
24th Apr, 2016 at 05:44:56pm
I"ll try 2 springs tomorrow and let you know the results! |
25th Apr, 2016 at 08:57:37pm
Tried a standard and green spring together.. Same problem; look @ https://www.youtube.com/watch?v=dhqb1SluV4o
26th Apr, 2016 at 12:15:56am
Not quite following the problem ?
26th Apr, 2016 at 07:21:29am
Part throttle lean off pipe fitted? On 26th Jan, 2012 Tom Fenton said:
177 Posts Member #: 10990 Advanced Member Hornsea |
26th Apr, 2016 at 06:33:25pm
Interesting!
26th Apr, 2016 at 07:56:46pm
Sounds like the same problem Burcy! At cruising speed AFR is fine (rich), but when I push the throttle it start spitting a little (no backfires or something like that) and AFR 15 - 19.
27th Apr, 2016 at 07:23:01am
Burcy. It's sounds like your fueling is spot on.
In the 13's at last!.. Just |
27th Apr, 2016 at 09:53:23am
Your right it is set up really well to be honest, maybe it's me just being a bit picky with it being lumpy off boost.
27th Apr, 2016 at 10:21:55am
for the hesitation it could need a set of plugs, maybe try the next warmer set. On 28th Aug, 2011 Kean said:
27th Apr, 2016 at 11:44:48am
On 26th Apr, 2016 burcy35 said:
Interesting! I have a similar issue when i am cruising off boost with part throttle. The afr is hovering around 14.5 -15.5 and the car starts hesitating slightly which is annoying when cruising in traffic but once boost comes in the fueling is spot on around 11.5. Do you think the thicker oil will help in my case? Cheers New plugs , smaller gap , more powerful coil 15.5 afr at cruise is good 16 is better.... 17-18 when I started having issues a nice stable lean cruise is awesome for economy Yes i moved to the darkside |
27th Apr, 2016 at 11:48:58am
Roland imo you looking at it the wrong way round imo if its too lean at part throttle / low throttle and even idle then you need to move the base mixture
27th Apr, 2016 at 12:16:17pm
Cheers fellas,
27th Apr, 2016 at 01:27:10pm
The symptoms do sound like the dashpot is moving upwards too quickly. You mention the dashpot is moving well - is there resistance to the piston moving upwards? I'd say to check you haven't blocked the port to the float chamber with the plenum gasket, but with it leaning out so much just revving the engine it is likely to be something else causing it. |
27th Apr, 2016 at 08:13:00pm
I find something similar, opening the throttle sharp tends to cause a brief lean out which as mentioned above seams to be the piston is rising too fast to allow enrichment. I tried thicker oil which helped but anything heavier than 20w caused me to have a slow throttle response (which feels like serious turbo lag). Instead I am trying to reprofile the needle in the area that covers acceleration. Have a look at the link below:
On 7th Nov, 2008 Nic said:
28th Apr, 2016 at 04:13:11pm
https://www.youtube.com/watch?v=cCc3MylBTfk
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
29th Apr, 2016 at 05:21:32am
Could it be the temp compensation Bi- metal in the HIF leaning out as it gets hotter. if you flush more fuel it cools down again ?? Edited by Sir Yun on 29th Apr, 2016. That sir, is not rust, it is the progressive mass reduction system
8th May, 2016 at 11:50:38am
Problem solved so far.. Changed the piston of the HIF,still using the original dashpot. Mixture is still a bit lean at low RPM, but the engine is feeling fine when I push the throttle.. The rest could be done by customizing the needle. Thanks for your help guys! |
8th May, 2016 at 08:31:11pm
What was up with the piston to cause the problem? |
