| Home > Help Needed / General Tech Chat > Using a turbo carb for n/a? | |||||||
![]() 192 Posts Member #: 837 Advanced Member rugby |
11th May, 2016 at 12:28:30pm
Hi chaps, been a while since I've posted.
11th May, 2016 at 04:17:32pm
I'm sure it'll work fine as is as it works off boost. My build thread..
11th May, 2016 at 05:53:56pm
it will be fine, the needle will need to be changed to an n/a needle though
Yes i moved to the darkside |
11th May, 2016 at 08:57:46pm
Haha yeah, I've got to change the spring too.
11th May, 2016 at 09:17:56pm
If you think about it the Turbo carb operates both under vacuum and boost, so there's no reason why you can't just run it in NA form.
