| Home > Help Needed / General Tech Chat > Irratic idle | |||||||
26th May, 2016 at 08:58:31pm
Hi
Edited by JT on 26th May, 2016. My build thread..
27th May, 2016 at 04:48:33am
That is quite possibly an air leak Yes i moved to the darkside |
27th May, 2016 at 06:11:59am
Ok. So could it be between the carb and head? Or could it be intercooler pipes etc as well? My build thread..
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
27th May, 2016 at 06:16:36am
You could spray some easy start all over the manifold ect to check for an air leak. We had one on the manifold when the engine first went in They don't die, they just get faster! |
27th May, 2016 at 09:40:54am
Ok ill try that. But I'm a bit concerned about the hot turbo etc in that area!
Edited by JT on 27th May, 2016. My build thread..
27th May, 2016 at 09:44:07am
Air leak between throttle and engine, not in the IC pipes.
27th May, 2016 at 11:42:12am
Cheers guys. I'll have a look over the weekend.
My build thread..
27th May, 2016 at 12:12:44pm
Heat could be related to it running lean - i.e an air leak:) Fastest 998 mini in the world? 13.05 1/4 mile 106mph
27th May, 2016 at 04:00:45pm
Yes I did wonder that wil.
My build thread..
28th May, 2016 at 04:32:26pm
Well I've sussed it!
My build thread..
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
28th May, 2016 at 05:19:06pm
Glad ya found the problem, weird about water temps mine never goes anywhere near past norm, oil temp on the other hand.. i suffer from seeing the wrong side of 100° when being on boost for long period of times Edited by D4VE on 28th May, 2016. On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
28th May, 2016 at 06:06:42pm
Oil sits at 90. But I haven't seen any more that 8psi and only for a quick test to show my mate and yest the bleed valve lol.
My build thread..
28th May, 2016 at 09:44:15pm
I dont think theres a need for an extra rad? Surely somethings up? On 24th Oct, 2015 jonny f said:
28th May, 2016 at 10:06:34pm
Could be the fact Im not running a mechanical fan.
My build thread..
