| Home > Help Needed / General Tech Chat > Backfire/misfire | |||||||
28 Posts Member #: 11086 Member Staffordshire |
17th Jun, 2016 at 06:34:16am
Morning guys, im quite new to this turbo stuff so bear with me!
Edited by Moggyton on 17th Jun, 2016. |
17th Jun, 2016 at 06:48:21am
Ive just checked the carb oil... And theres hardly anything in there. Could this be the problem? |
336 Posts Member #: 9941 Senior Member Derby |
17th Jun, 2016 at 07:23:43am
What ignition system you using |
17th Jun, 2016 at 07:55:49am
Electronic ignition Edited by Moggyton on 17th Jun, 2016. |
17th Jun, 2016 at 01:07:43pm
Ive put some 80w90 in the carb but its still backfiring when boost comes in... |
2 Posts Member #: 11384 Junior Member Northamptonshire |
17th Jun, 2016 at 11:11:57pm
What coil are you running?
18th Jun, 2016 at 06:46:11am
Coil was changed when it was mapped by aldons so its one of theres.
18th Jun, 2016 at 07:51:15am
Do you have an AFR gauge ?
18th Jun, 2016 at 10:33:40am
I do have an afr gauge. I thought abouta boost leak but i cant find anything :( |
18th Jun, 2016 at 11:26:35am
What does the AFR gauge show once the misfire starts ?
18th Jun, 2016 at 11:34:44am
Yes wideband, ill have to go for a drive and have a look, im sure it was going lean! |
18th Jun, 2016 at 07:53:21pm
Fuel pressure/supply would be an obvious thing to check.
19th Jun, 2016 at 06:03:59am
Fuel pressure doesnt drop when boost comes on.
19th Jun, 2016 at 09:04:21am
And for clarity...is this problem there all the time now ?
19th Jun, 2016 at 09:21:16am
On 18th Jun, 2016 Moggyton said:
Yes wideband, ill have to go for a drive and have a look, im sure it was going lean! Watch what it shows immediately before the misfire occurs. A wideband can give very false readings in the event of a misfire, for example a misfire caused by the mixture being too rich can cause a wideband to suddenly read lean because they measure residual oxygen in the exhaust gas of which there is lots if the fuel doesn't get burnt. It's not that straightforward with a turbo as the fuel/oxygen can burn after the exaust valve inside the turbo itself and I doubt if it is over-rich from the rest of your description but certainly worth looking at what the AFR is immediately before the misfire occurs. Having some form of data logging would be even better.... Schrödinger's cat - so which one am I ??? |
19th Jun, 2016 at 03:26:23pm
Problem is still there yes. Even when the car is just starting to get warm.
19th Jun, 2016 at 03:27:29pm
Ill take it for a drive shortly and report back about the AFR readings.
19th Jun, 2016 at 03:48:37pm
Have you done a compression test and/or checked valve (tappet) clearances ?
19th Jun, 2016 at 04:26:45pm
Un leaded yes |
