Home > Help Needed / General Tech Chat > turbo oil feed
c2_mad
Member #: 4215
hi guys,
i am thinking about making a oil feed pipe with AN type fittings. anybody done this before? any problems? can they handle the pressure? any tips?
thanks
tadge44
Member #: 2500
Buckinghamshire
Oil feed to turbo is a very small diameter sol that the pressure is not an issue. AN fittings should be OK in most applications.
Mike-998
Member #: 9774
Buckinghamshire
AN style fittings are used in hydraulic applications which see pressures in the order of 1000psi. So long as you use the correct method to seal them to the hose you should have no problem. Most manufacturers/retailers should publish the pressure rating of the fitting if you are unsure. It would also be worth using PTFE lined hose for longevity if it's for oil.
JT
Member #: 637
Hertfordshire
I used AN fittings for my oil cooler and turbo oil feed. Think I used AN8 for cooler and AN4 for the oil feed.
My build thread..
c2_mad
Member #: 4215
thanks guys*wink*
JT
Member #: 637
Hertfordshire
I might of used AN6 for my turbo feed, can't remember. I'm sure there's a table online that says what the actual sizes are
My build thread..
slater
Member #: 1291
Suffolk / Birmingham
I use the brake line style fittings but its all good.
t@z
Member #: 452
Chester, UK
-4 is garrett recommended size, but i have used -3 on my old T2 with no problems
www.twitter.com/lilpinkiy
Ive always used -4
on my ball bearing 'super' T 3 i used -4 with 2x 1.5mm restrictors
The drain is more important imo
The turbo will only use the amount of oil it can
But it needs to return it restriction free
Oil feed too small = bad though
Too much pressure can push past the seals
But dont confuse too much pressure with too big of a feed its not the same
JT
Member #: 637
Hertfordshire
Would too big a feed cause smoking at idle do you think?
My build thread..
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
as brett says you could feed the turbo with -8 if you wanted so long as the turbo is healthy it will only use a small flow
just be sure the drain is free and well flowing wit a good size to it as a crap drain is nearly always the smokey exhaust problem
