Home > Help Needed / General Tech Chat > Swiftune oil catch tank
Callum
Member #: 10396
Stoke-on-Trent
I'm getting all the holes drilled before I put some paint on the mk2. I'm fitting a swiftune catch tank, don't know if I would be best to pass the hose from the engine bay straight through the inner wing with a grommet or have a pipe fitting bolted through the inner wing with either side of the pipe connected to it. What are your thoughts or doesn't it really matter?
On high pressure fuel or brakes then I'd use bulkhead fittings. But for a low pressure breather pipe more connections is more places for leaks or issues. I'd grommet it, or more likely use Rayrim edging.
Callum
Member #: 10396
Stoke-on-Trent
Thanks tom
