Home > Help Needed / General Tech Chat > 998 na 1275 head rebuild but still issues
Rammie2000
Member #: 10190
belgium
So the 998 got a rebuild. Its reving well but it used to rev to 7 k easy with this set up. Now its starts to spit and puf on 5 k rpm top. In 1st it easily gos up the revs but all the rest stops at aprox 5 k rpm. I set the ignition with strobo to 8 degree ( otherwise ibset it by ear till it tuns smooth and that meant 14 degree! ) fueling seems fine though ( nice brown plugs)
blocked fuel filter?
Rammie2000
Member #: 10190
belgium
No fuel filter in there. Now. Did some more testing. And noticed it does have to be fueling. When i drive at 3/4 trotle it dos pul straight to 6 k rpm. And should be put a bit richer. ( fresh fuel in now... hiw fast can fuel detiriate)
is there a little woven filter in the carb ?
Rammie2000
Member #: 10190
belgium
no. and carbs been rebuild. start to suspect the fuel pump not being strong enough to fill both carbs fast enough.
Rammie2000
Member #: 10190
belgium
set the mixture on the edge of to rich but still ... if i give it like 3 mm less then full throttle it go's really good to 5500 a 6000 rpm and easily does 150 kmh on the trip master. but floor it and it starts to ratle again ignition on 8 degrees or even up to 16 makes no difference. suspecting the electronic dizzy.
