| Home > Help Needed / General Tech Chat > Opening rear quarter window catch's ? / non gen clubman wings | |||||||
13th Jul, 2016 at 05:42:56pm
Evening all , first up we have a customers car in and he has bought new opening rear window mechanisms as the old ones are worn and rattle ! Now it looks like the whole chrome around the window needs splitting somehow to replace them , has anyone had any experiance with them .
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
13th Jul, 2016 at 05:48:19pm
They have tiny screw on one side and a rivett on the other.. just undo the screw, didnt realise you could buy these new tho?
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
13th Jul, 2016 at 09:37:25pm
Seen the serew and rivet but seams like it will bent the chrome surround ! Im gathering it will just be tight due to never being removed?
13th Jul, 2016 at 10:19:43pm
Theyll be some sort of sealant in there too? When ive done them once the screws out it pops away.. where are frames new? On 24th Oct, 2015 jonny f said:
14th Jul, 2016 at 09:52:50am
as Dave said, the window surrounds come apart when you remove the grub screw. I removed the glass from mine to paint the frames black. There is a rubber seal between the glass and frame if I recall right which was quick rigid (I assume it was just old) which took a bit of persuasion to separate.
603 Posts Member #: 1938 Post Whore near Dundee |
15th Jul, 2016 at 09:47:09am
you'll probably find when you remove the little screw that they will ping open.
