Home > Help Needed / General Tech Chat > Cinquecento Roundnose
t@z
Member #: 452
Chester, UK
hi, bit off a random one as was faffing with this today. i've done some searches but either im shit at it but i cannot find any info on what needs cutting and how much to get the fucker to fit.
anyone got any guidence?
t
www.twitter.com/lilpinkiy
Mike-998
Member #: 9774
Buckinghamshire
I was looking into this a couple of weeks ago, there are a few threads but nothing too specific that I could find either. From looking at pictures though I think the best way is to remove the vertical section out the grill area and cut a cm or two out of the bottom of the front panel and cant the grill backwards slightly. Then just space the grill out so that it clears the rad.
You'll either need to modify the starter motor or fit one with the solenoid closer to the engine block if you're using a pre-engaged starter.
Edited by Mike-998 on 16th Jul, 2016.
jonny f
Member #: 9894
Dorking
Mine went in a minus without cutting anything from the body. I did bend it a little over my knee and chopped a bit of plastic of the tank.
