| Home > Help Needed / General Tech Chat > Seizing front ally calipers | |||||||
313 Posts Member #: 9367 Senior Member Derby |
16th Jul, 2016 at 08:33:40pm
So I've been running mini sport alloy 4 pots for years now and on Friday night I did a track day at donington and they started seizing.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
16th Jul, 2016 at 08:45:30pm
Could well be the heat.. i warped some discs once from heat.. it was ever so slightly but enough to boil them and brakes would stick on.. cool down theyd be fine.. drive for few miles without pressing brake pedal and theyd still stick.. as soon as i changed discs the problem stopped On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
16th Jul, 2016 at 11:02:57pm
Master cylinder could cause it. When they are stuck on see if cracking the bleed nipple off releases them.
16th Jul, 2016 at 11:03:04pm
How old are they and have you ever cleaned the pistons and bores?
17th Jul, 2016 at 09:05:02am
Master cylinder is a 1inch AP one. Not standard mini if that makes a difference. |
17th Jul, 2016 at 09:06:43am
I'll take them off and have a look for any dirt. I'll also try the pedal now things have cooled down and see if it makes any difference. Just not had chance yet. |
17th Jul, 2016 at 09:21:44am
It's got to be hydraulic. If they were seized on corrosion or dirt or whatever then they'd stay seized! The fact that they do release means either a hose is collapsing, the master isn't returning properly, or maybe the pushrod needs shortening a fraction.
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
11th Oct, 2017 at 04:03:55pm
Just reading this old post.. Tom (or anyone else) can you elaborate on why the pushrod needs shortening. Is it because its the wrong pushrod, i.e. one for a servo?
