Home > Help Needed / General Tech Chat > Smiths tacho with megajolt
JT
Member #: 637
Hertfordshire
Hi
I have this tacho. ...
Just wondering how people have wired them up with megajolt?
Mine seems to work at idle and lower/calmer revs, but as soon as I drive a bit more spirited it goes all over the place!
At the moment I have it wired to the megajolt tacho out put.
Any thoughts?
My build thread..
viz139
Member #: 9182
You may find you also need this
http://trigger-wheels.com/store/contents/en-uk/p129.html
scoop-face
Member #: 11122
Scottish Borders.
Do you have a good earth? My tacho used to blink a lot, turned out to be an earth problem.
JT
Member #: 637
Hertfordshire
I'll check out the earth. Think it's the same as the other gauges and engine earth though :/
My build thread..
longy
Member #: 2727
Bicester
Check out the autosportlabs MJLJ V4 manual. frustratingly i have the RVI tacho, your RVC should work fine.
https://wiki.autosportlabs.com/MJLJ_V4_vehi...tallation_guide
About 2/3 down the page
1972 998 TURBO SLEEPER
JT
Member #: 637
Hertfordshire
I've got megajolt v3
I should add the tacho has a few different ways of wiring it up.
There's a high out put and a low out put. I'll get a pic of the instructions next time I'm at the workshop.
My build thread..
