| Home > Help Needed / General Tech Chat > Twin Su hif 38 In blow trow setup | |||||||
5 Posts Member #: 11420 Junior Member Stuttgart (Germany) |
10th Aug, 2016 at 05:37:27pm
Hi guys
10th Aug, 2016 at 06:07:41pm
You could, probably using two hif44 turbo rebuild kits and machining the carbs for the seals, but it would be a lot of hassle trying to get that setup properly especially if the needles need profiling to suit, and you would need a large custom plenum or pitot tubes fabricated in what is an already very tight engine bay with a single hif44 and metro plenum fitted. On 26th Jan, 2012 Tom Fenton said:
10th Aug, 2016 at 06:24:17pm
Thanks for the fast answer
10th Aug, 2016 at 06:34:34pm
this is somthing quite a few people have looked at doing, but Ive only seen it done with Webers,
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
10th Aug, 2016 at 10:27:15pm
Lots if people say the same but i think twins would warrant an investigation.... A pair of 1.5s would make no extra power but the drivability should be better at low revs when you snap open the throttle, usually at this point a hif6 momentarily goes lean because of its size. (Two smaller carbs can respond faster.)
On 10th Aug, 2016 Joe C said:
this is somthing quite a few people have looked at doing, but Ive only seen it done with Webers, essentially there is little point, the HIF44 dosent start becominf restrictive untill around 250 hp, so not really woth the head ache in my opinion, |
