| Home > Help Needed / General Tech Chat > White/oil smoke at idle | |||||||
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
10th Aug, 2016 at 08:30:03pm
Got the turbo build running with a BDD needle. Currently bit rich, running 11-12:1 at idle. Haven't driven it yet to see what happens under boost though, so bit reluctant to lean it off yet.
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
10th Aug, 2016 at 09:43:29pm
lean it off at idle, it will make next to no difference to the rest of the rev range. On 28th Aug, 2011 Kean said:
10th Aug, 2016 at 10:42:25pm
OK thanks, will do. Around 14:1?
11th Aug, 2016 at 05:09:55pm
Probably turbo seals, get the engine up to temp if you haven't already and see if it clears On 26th Jan, 2012 Tom Fenton said:
3rd Sep, 2016 at 09:27:03pm
Had the engine up to temp now, and although it still smells a bit smokey, the main smoke does clear. Next time you start it up after its sat a while the smoke comes back.
3rd Sep, 2016 at 10:32:10pm
Could be valve seals/guides if it comes back after it's been sitting On 20th Oct, 2015 Tom Fenton said:
3rd Sep, 2016 at 11:03:31pm
Shouldn't be that as it's a new Benross head. 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
4th Sep, 2016 at 09:13:31am
I had a bit at idle when I first built the engine. It has cleared now, I think it was just the rings bedding in, which took a while. I run a supercharger and I don't care the TB is on the wrong side.
7th Sep, 2016 at 11:26:27am
if it was my engine and the tune was ok id go and do some high way runs ie get up to 80kph and go flat floor till 120 or so then lift off till 80 kph then back on it till 120 lift and so on for a good few cycles this creates cylender pressure pushing the rings out to the bore and then the of throttle pulls a vacume that takes the crud off the cylender walls imo its a way to seat the rings threw heat cycleing and pressure at he end of the day it up to the bore finish anf ring pack and build qulity but a goos strong run in on and off power imo makes a goos sealing ring set
10th Sep, 2016 at 09:11:08pm
Fairly certain it's turbo, not rings now.
