| Home > Help Needed / General Tech Chat > Engine flooded with fuel | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
14th Aug, 2016 at 07:05:15pm
Ive just finished putting my engine together, but when i turn the fuel pump the engine gets flooded with fuel instead of returning to the fuel tank, its a N/A carb converted for turbo use, im using a Malpassi regulator and an MPI fuel tank. any thoughts? 1972 998 TURBO SLEEPER |
14th Aug, 2016 at 07:06:59pm
Float is stuck in the carb? My build thread..
14th Aug, 2016 at 07:11:23pm
could be, ive only just rebuilt it though. 1972 998 TURBO SLEEPER |
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
14th Aug, 2016 at 07:21:33pm
Check your fuel pressure mate |
14th Aug, 2016 at 07:22:13pm
either the float valve as above, or the reg is overloading the carb.
14th Aug, 2016 at 07:57:22pm
Cheers Joe, what do you mean by the regnover loading the carb? I have a fuel pressure gauge between the reg and carb and it's reading 11 psi is that too high? 1972 998 TURBO SLEEPER |
14th Aug, 2016 at 08:03:28pm
At idle its too high
My build thread..
14th Aug, 2016 at 08:06:28pm
Oh ok thanks 1972 998 TURBO SLEEPER |
14th Aug, 2016 at 08:19:11pm
yeah far to high LOL
14th Aug, 2016 at 08:38:02pm
Check ypu haven't accidentally fitted the carbs fuel line to the wrong connection, I accidentally did that once while checking fuel pressure. On 26th Jan, 2012 Tom Fenton said:
15th Aug, 2016 at 08:02:51am
Thanks Joe, all the fuel should have evaporated off the engine bay by now so ill have a go again tonight.
15th Aug, 2016 at 08:05:19am
LOL oh dear!
Edited by Joe C on 15th Aug, 2016. On 28th Aug, 2011 Kean said:
15th Aug, 2016 at 12:31:52pm
I would drop the oil for sure. On 26th Oct, 2004 TurboDave16v said:
