| Home > Help Needed / General Tech Chat > Choke seals leaking | |||||||
116 Posts Member #: 10945 Advanced Member scarborough/ northyorkshire |
15th Aug, 2016 at 08:53:55pm
Choke seals are leaking fuel on my rebuild su, iv replace them twice with the correct new ones but still no joy, I bought another carb to see if I'd put it together ok and everything's ok it a hiff44 converted for turbo, it runs perfectly just leaks on boost, anyone have any ideas |
16th Aug, 2016 at 08:01:57am
Anyone |
16th Aug, 2016 at 11:39:51am
The last time I rebuilt a carb I found the choke O rings in the kit from burlen were actually too small, and would not have sealed if fitted. Are you sure the O rings are the correct size? |
16th Aug, 2016 at 11:48:34am
Have you checked fuel pressure,
16th Aug, 2016 at 04:30:24pm
I've had this before. To be honest the choke seals that come in the kit are pretty crap. Sometimes they seem ok, but ive used some larger o rings from something else before.
16th Aug, 2016 at 07:19:40pm
Fuel pressures 4 psi when idling, it's a new pressure regulator,il try some bigger seals if that don't work burlen sell the choke assemberly for £60. |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
17th Aug, 2016 at 09:53:37am
Try 3psi? On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
17th Aug, 2016 at 03:34:44pm
Had the same issue with mine years ago when I used a burlen rebuild kit, I put some thicker O rings in which sorted it.
