Page: |
Home > Help Needed / General Tech Chat > Intake temp | |||||||
190 Posts Member #: 8935 Advanced Member netherlands |
29th Aug, 2016 at 09:41:43am
Hi
29th Aug, 2016 at 10:01:06am
what turbo?
29th Aug, 2016 at 10:24:04am
Its a gt1752 |
29th Aug, 2016 at 11:46:35am
might see a few degrees lower then.
2742 Posts Member #: 637 Post Whore Hertfordshire |
29th Aug, 2016 at 03:32:09pm
I got a temperature gauge off ebay but it goes blank as soon as I turn the engine on. Very annoying. Think it has a lose conection inside it.
My build thread..
116 Posts Member #: 10945 Advanced Member scarborough/ northyorkshire |
29th Aug, 2016 at 08:44:09pm
this is something I'm wanting to know too as I'm using an escort rs intercooler and I don't think its up to the job past 10 psi,what gauge and senser are you using ,cheers |
29th Aug, 2016 at 08:57:57pm
http://www.ebay.co.uk/itm/162128287055
My build thread..
30th Aug, 2016 at 06:07:11pm
I have a similar display that also goes blank at times, and it took some tracking down as to exactly when it happens. I initially got around it by putting an inline switch in the power supply which allowed me to power cycle it and get the display back, without having to turn the ignition off. I've finally noticed that it always goes blank after I've turned the lights off or flashed the headlamps, and I suspect there is a spike on my choice of ground that kills the LCD display. I haven't had chance to check the theory yet by putting a diode in the circuit to ground, but I suspect it will work. Have you tried cycling the power to the display after you have started the engine, as you might have a similar problem to me?
On 29th Aug, 2016 JT said:
I got a temperature gauge off ebay but it goes blank as soon as I turn the engine on. Very annoying. Think it has a lose conection inside it. When I've got it to work it's been about 35°c after a burst of full throttle. Running 8psi. It's not a cossie cooler though. |
30th Aug, 2016 at 06:45:35pm
I haven't tried that. But it seems to work if I wiggle the earth and live wires. Very annoying. The guy hasn't responded to me yet either.
My build thread..
852 Posts Member #: 951 Post Whore Bromsgrove |
31st Aug, 2016 at 03:13:16pm
At the end of the 1/4 mile I see 90C into the cooler and 40C out, GT1752 at 18 psi 'Where does the engine go?' |
31st Aug, 2016 at 04:04:09pm
On 31st Aug, 2016 steve1275 said:
At the end of the 1/4 mile I see 90C into the cooler and 40C out, GT1752 at 18 psi That's not bad. what cooler are you using? My build thread..
1st Sep, 2016 at 06:55:24am
What temps do you start to see power loss ? |
539 Posts Member #: 6807 Post Whore York |
1st Sep, 2016 at 08:58:37am
On 1st Sep, 2016 fixitphil2 said:
What temps do you start to see power loss ? Single dimension question to a multi dimensional problem. Power production is proportional to the mass of air that you can fill the cylinder with. Therefore power production at 40 deg IAT will be lower than 30 deg IAT due to a lower density air charge in the cylinder. |
1st Sep, 2016 at 01:26:28pm
90 deg in and 40 deg out is pretty typical. You'll do well to better that.
1st Sep, 2016 at 04:00:55pm
Do you think there's much gain to have the air filter right up front behind the grille in fresh air? As opposed to at the back of the engine bay? My build thread..
1st Sep, 2016 at 04:37:11pm
it'll help, but failing that a duct toward the filter or proping the back of the bonnet up will get you pretty much there.
13th Sep, 2016 at 05:51:07am
drove it on track last weekend
13th Sep, 2016 at 07:54:20am
sounds fair, track time is pretty full on so uif its going to creep up it will be there or on the rollers.
13th Sep, 2016 at 09:07:49am
its a front mounted cossie 2wd intercooler
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
13th Sep, 2016 at 09:40:16am
Is it ducted at all, any airflow coming in the front of the car will try to take the easiest route which is around the intercooler. If you can fill in any gaps then the air has to flow through the cooler, makes a good difference.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
13th Sep, 2016 at 11:11:00am
50 degrees at full chat isn't bad in the high ambients. Its knocked 50 degrees off it or there abouts.
13th Sep, 2016 at 11:43:30am
the cozzy cooler tends to sit lust behind the bonnet so dosent get a lot of flow (Assuming this isnt a clubby), and still works well despite this,
13th Sep, 2016 at 12:39:28pm
its behind 5 big holes to cool |
13th Sep, 2016 at 04:57:59pm
Air needs to get out aswell.
13th Sep, 2016 at 07:58:09pm
got an airscoop at the bonnet also with 4 holes underneath it |
Page: |
