| Home > Help Needed / General Tech Chat > ECU Options | |||||||
81 Posts Member #: 11403 Advanced Member |
2nd Sep, 2016 at 09:04:40pm
Which ECU is recommended to go with? I have seen Megajolt and Megasquirt but now Ive just saw Aldons Amethyst and a one called NoDiz
2nd Sep, 2016 at 09:46:11pm
Do you need it purely for ignition ? Or are you wanting to run fuel injection ?
Edited by Turbo Phil on 2nd Sep, 2016. |
3rd Sep, 2016 at 07:10:18am
Id use Vems in even just for ignition. You'd get dual wideband, knock, egt and boost control all in one box with the optional 52mm gauge like any other common Wideband. On 26th Oct, 2004 TurboDave16v said:
3rd Sep, 2016 at 11:23:50am
Hi, no not planning on fuel injection, but planning on turbo
3rd Sep, 2016 at 11:40:14am
Can't go to far wrong with Megajolt really. Complete kits can be picked up for a decent price second hand.
3rd Sep, 2016 at 01:38:34pm
thanks will keep a look out, Im guessing its better than the Aldon Amethyst? |
3rd Sep, 2016 at 06:34:26pm
Yes, the amethis takes it input from a dizzy or similar, so 4 pulses per revolution, where as the jolt uses a 36-1 tooth wheel so resolution is better,
6th Sep, 2016 at 05:45:20pm
Nodiz does have MAP capability and doesn't need the EDIS module to drive the coil. It also has bluetooth and a phone app. I use megajolt, so I don't know how good or bad nodiz is, but on paper it has extra capabilities that megajolt should have had years ago. |
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
2nd Oct, 2018 at 06:28:41pm
Hi All,
2nd Oct, 2018 at 08:47:48pm
Megajolt just does ignition,
2nd Oct, 2018 at 11:08:22pm
Thanks Joe, that’s tomorrow night sorted then 👍🏻 |
