| Home > Help Needed / General Tech Chat > Calculate diff ratio without counting teeth? | |||||||
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
20th Sep, 2016 at 04:48:47pm
Hi guys,
20th Sep, 2016 at 05:28:24pm
Yeh. Get it on level ground. Plugs out. Mark the crank pulley and a tyre, put it in 4th gear. Pull it along counting how many times the crank turns while a mate counts how many times the wheels turn. Then devide the two.
20th Sep, 2016 at 08:16:43pm
If you've an accurate speedo or gps, you could work it out with the revs? A bit rough but it could work |
20th Sep, 2016 at 08:30:28pm
Use guessworks gearbox ratio calc, plug in a few things and see what comes up the closest in each of the gears with regards to speed/rpm relations On 26th Jan, 2012 Tom Fenton said:
