Home > Help Needed / General Tech Chat > Inlet gauge wiring proplems
JT
Member #: 637
Hertfordshire
HI
I bought from ebay a neat little digital inlet temperature gauge. It has a sensor at the end of a wire. Earth and live.
http://www.ebay.co.uk/itm/201295325567
I've wired it up earth to earth, live to switched live. It works perfectly displaying a temperature.
As soon as I fire the car up it just goes blank. Still lite up just not displaying a temperature. As soon as I turn the engine off, it displays the temperature again.
I tries fitting a diode but same thing.
I sent one back and got one returned but same thing.
Any ideas before I send it back and get my money back?
Thanks
Josh
Edited by JT on 21st Sep, 2016.
My build thread..
Kean
Member #: 341
aka T2clubby
South Staffs
Voltage too high once the alternator is online. You'll need a 12v voltage regulator to supply it.
JT
Member #: 637
Hertfordshire
Thanks kean.
Is thst like what's on the fuel gauge?
My build thread..
The one I bought years ago had some kind of resistor with it that needed wiring in for this purpose iirc ?
Phil.
JT
Member #: 637
Hertfordshire
Cheers guys.
Is a resistor the same as a regulator?
My build thread..
JT
Member #: 637
Hertfordshire
Would this work?
http://www.ebay.co.uk/itm/171287805868
My build thread..
D4VE
Member #: 10749
lowestoft suffolk
Sounds like what mine does but mine just works when it wants too... ? Theres no real pattern to when it decides not to show a temp i just assumed dodgy cheap guage?
Nothing gets past Dave lol
viz139
Member #: 9182
The regulator on the fuel gauge is mecanical ( on/off) What you may need is an electronic voltage regulator.
http://ie.rs-online.com/web/p/linear-volta...lators/7044010/
metroturbo
Member #: 989
North Yorkshire
They normally come with a zener diode regulator to make them suitable for 12V use. I think they need 5V by design. You can buy DC voltage regulators dirt cheap if you don't want to mess about with a zener diode. http://www.ebay.co.uk/itm/5x-Voltage-Regul...K7cDwCj8tRie-8w
JT
Member #: 637
Hertfordshire
Thanks mate
I take it I need a 12v version?
My build thread..
metroturbo
Member #: 989
North Yorkshire
Looking at the gauge, I'd say 12V would be correct. It does sound as though it already has some kind of voltage regulator already, though. Is there anything on the supply cable at all?
JT
Member #: 637
Hertfordshire
Nothing at all
My build thread..
That's the component that came with the gauge I bought. That looks like it should do the trick.
Phil.
JT
Member #: 637
Hertfordshire
Fantastic the guy I bought it from has no idea!!
He reckons it reads from 200c°-1200c°! And just needs to get up to temperature!! Lol
I take it you just wire these regulators in to the power?
My build thread..
metroturbo
Member #: 989
North Yorkshire
They are pretty straight forward to connect up. The pin out will be easy to find on the net. One pin is ground, one is supply, one is output. I haven't checked the specs of the one in the ebay link as I was thinking you'd need 5V rather than 12V. You need to check what the supply voltage range of the chip is, as the supply voltage might not be high enough.
Ebay description says the display needs 9-12v. Outside of that it might not work.
5v will be too low and 13.4v from the alternator will be too high
JT
Member #: 637
Hertfordshire
I fitted one of these as advised above...
http://www.ebay.co.uk/itm/301365977790
And it works perfectly!!
Thanks guys!!
My build thread..
Nice one !
Phil.
viz139
Member #: 9182
Its nice to see advice work in practice, especially with minis. *smiley*
