Home > Help Needed / General Tech Chat > rear subframe removal problems
welshdan
Member #: 1111
s wales
I made a start changing the rear subframe tonight. This is my first attempt at this so bear with me!
basically I have removed the braking (pipes and cables), battery cable disconnected, bolts removed from the boot floor, bolts removed from the heelboard. As far as I can see there is nothing left connected, it should just fall away but seems to be stuck fast to the healboard
Is there anything that I am overlooking or do I need to use a bit of brute force? As I said there is nothing obvious holding it in place still
Cheers, Dan
welshdan
Member #: 1111
s wales
Also removed the fuel filter bracket
Shocker bolts removed ?
It will be tight give it a good wiggle , if i remember right the heel board bit wants to drop down slightly first otherwise the mounts foul on the rear valence corners
welshdan
Member #: 1111
s wales
Hi Rick, yes the shocks are off. Will go and have another look in a minute. It really wouldnt budge last night!
it normally needs a bit of persuasion with a pry bar
welshdan
Member #: 1111
s wales
Its off now cheers chaps. Got to sort some welding hopefully will have it running again by the weekend pending delivery of parts
