| Home > Help Needed / General Tech Chat > Painting in the boot - spray gun access | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
5th Oct, 2016 at 08:33:39pm
I've just laid a couple of coats of primer in the engine bay and boot but I had a really hard time getting the gun into the extremities of the boot.
Edited by adcyork on 5th Oct, 2016. |
5th Oct, 2016 at 08:52:30pm
Maybe use a swivel hose adapter on the bottom and remote mount any reg/filter to a short distance away ?
5th Oct, 2016 at 09:02:05pm
Take the inline trap off, can you get one mounted to the wall if require it.
5th Oct, 2016 at 11:14:43pm
Thanks for the suggestions.
5th Oct, 2016 at 11:14:45pm
6th Oct, 2016 at 06:49:59am
You might struggle with the smaller gun to wet it all up , the boot area is a swine as it will allways fill with overspray so you carnt see what your doing . , as said get rid pf ghe trap , the weather is turning now anyway so so shouldnt struggle with water as much as in the summer . |
6th Oct, 2016 at 11:16:39am
reduce over spray by dropping the air pressure and open the flow up but you'll have to move a bit faster to not get runs as this is more or less just throwing paint at the panel not misting it but it can be useful in those blind corners and hard to get at bits where the air wants to push the paint out before it gets a chance to hit the panel
6th Oct, 2016 at 06:21:55pm
I would say get one of those small guns used for painting wheels predominantly, and just do the awkward bits, then overpaint with a larger gun as normal so you know nothing has been missed. On 26th Jan, 2012 Tom Fenton said:
