Home > Help Needed / General Tech Chat > Cooper s conrods dimensions
giannoutsos
Member #: 8952
Athens Greece
Good morning all,
I have decided to order some aftermarket rods for my engine, can someone please confirm that these are the correct dimensions for Cooper s conrods:
Length c-c 146mm. (1.625" is 146.05?)
B/E bore 44.98mm
S/E bore 20.65mm
B/E W 26.2mm
S/E W 22.5mm
Thanks in advance
giannoutsos
Member #: 8952
Athens Greece
From the factory data I have for the 1275 Cooper S Con Rod, P/N AEG520, the following;-
Centre to Centre 5.75"
Big End Bore dia 1.7705" to 1.7710"
Little End dia 0.8109" to 0.8116"
Big End Width 1.060"
Little End Width 0.876"
Centre to Centre Off-set 0.177"
giannoutsos
Member #: 8952
Athens Greece
The answer above is from mr Spider, in case anyone else needs it.
Edited by giannoutsos on 11th Oct, 2016.
