| Home > Help Needed / General Tech Chat > Ignition timing vs cr | |||||||
116 Posts Member #: 10945 Advanced Member scarborough/ northyorkshire |
16th Oct, 2016 at 02:03:34pm
How much difference will ignition timing need to be altered if you changed your cr from say 9.1 to 8.5.1, just after a ball park figure,2 or 3 degrees? |
16th Oct, 2016 at 02:48:15pm
When I ran that compression ratio I found I needed about 16 degrees for it to idle nicely. The lower the compression the more timing you should need for the engine to pull nicely off boost.
16th Oct, 2016 at 04:26:40pm
Yes it's poor before 2000rpm till boost just starts since changing pistons from 6cc disc to omega 10 cc I changed cam at same time from standard 1275 to a Avon ph2 It drove a lot better before and not much quicker than before cam.on boost will it need more advance on lower cr? |
16th Oct, 2016 at 04:49:22pm
If you're running the same boost, but a lower cr in theory you should be able to run more advance.
17th Oct, 2016 at 05:29:31am
I found the p2 to be rather boring off cam and off boost in and around the rpms you plod about town
Yes i moved to the darkside |
17th Oct, 2016 at 05:51:37am
I nearly got the kc500 , but read good things about p2,wish I had as I don't like revving past 6000 rpm any way. |
