| Home > General Chat > advise please people | |||||||
![]() 341 Posts Member #: 259 Member grays, essex |
18th Sep, 2005 at 06:26:36pm
Trundled over to borough green 2day 2collect a 'TURBO' head that i got off ebay. Wen i got there we chatted for a whil, done the dodgy deal and i came home. Ive just re-painted it and it looks lovely but ive noticed that it doesnt have double valve springs! It was stated on the ebay post that it has sodium filled exhaust valves, but can you have a trbo head with these and not the double valve springs? Edited by 1976_mini on 18th Sep, 2005. it may b small but it purfectly formed
18th Sep, 2005 at 06:31:19pm
18th Sep, 2005 at 06:36:04pm
i no they dont but can you have turbo head without double valve springs?
18th Sep, 2005 at 06:39:36pm
well if standard turbo heads dont come with double valve spring i guess that it may be ok Crystal Sound Audio said:
18th Sep, 2005 at 06:46:54pm
If not is there any other way of telling wether the head is turbo spec or not?
18th Sep, 2005 at 06:49:40pm
thnks dangerous, i take it that they are the sizes for the turbo spec?
18th Sep, 2005 at 07:04:47pm
also have a look for a little 'T' stamped by the heater tap take off. but as dangerous says the only way to definately tell is to look for the larger dia exh valve stems. On 20th Oct, 2015 Tom Fenton said:
18th Sep, 2005 at 08:14:07pm
take the rockers off, and you should be able to see quickly that the exhausts valve is thicker than the inlet valve. If they are the same size, then you've been done! On 15th May, 2009 TurboDave said:
18th Sep, 2005 at 08:25:30pm
Standard turbo heads have double valve springs or atleast all the ones ive took apart have.
18th Sep, 2005 at 08:32:20pm
ive never had doubles on any of the turbos i have scrapped
18th Sep, 2005 at 08:39:26pm
Strange isnt it! |
18th Sep, 2005 at 09:21:12pm
I have at least 5 Turbo heads, and all of them have double springs fitted. Haven't we had this debate before ? lol.
18th Sep, 2005 at 09:27:22pm
fuckers! ive been had, NO double valve springs, BOTH inlet/exhaust valve stems are the same size! how can anyone out there be so selfish as to take advantage (and money) off a 19yr old who is still learning turbo stuff! y is the world full of wankers!
18th Sep, 2005 at 09:36:24pm
18th Sep, 2005 at 09:38:57pm
not yet, good job im a bit slow! I cant believe he asked me ?160 for it! Gud job i only gave him ?45
18th Sep, 2005 at 10:19:58pm
On 18/09/2005 21:27:22 1976_mini said:
anyone got a REAL turbo head for sale? I have a cracked one I may sell so the valves/springs and caps should be ok
Edited by Dangerous on 18th Sep, 2005.
18th Sep, 2005 at 10:26:34pm
was it this one
18th Sep, 2005 at 10:54:50pm
dangerous has all the bits and i have a bare casting with some light surface rust Crystal Sound Audio said:
18th Sep, 2005 at 11:31:16pm
yes it was that one dangerous! how did you guess? how much do you want for all the bits then dangerous? it may b small but it purfectly formed
20th Sep, 2005 at 07:03:10pm
All may not be lost. Have you measured the valves ? if it does indeed have 35.6mm inlets then it'll most likely be a normally aspirated MG Metro head. This has the bigger inlet valve and the ports are also of slightly larger diameter, so why not fit new exhaust guides and the sodium valves to this head ? That way you've got a decent head for not much money.
20th Sep, 2005 at 08:27:55pm
that was my next option!
21st Sep, 2005 at 03:25:07pm
why bother with sodium filled exhaust valves? On 15th May, 2009 TurboDave said:
21st Sep, 2005 at 03:37:45pm
good stainless ones are just as good |
21st Sep, 2005 at 03:49:37pm
exactly, I'm using stainless exhaust valves. touch wood, no problems On 15th May, 2009 TurboDave said:
21st Sep, 2005 at 10:24:46pm
how much are they jim? are they also 8mm like the sodium ones? it may b small but it purfectly formed
